Is there any significant difference in these 2 kits? I notice one has the center post already bolted on the bracket.
WE25X205
WE25M40
GE Rear Bearing Kits
#1
Posted 18 January 2013 - 12:29 AM
#2
Posted 18 January 2013 - 01:34 AM
Same kit/different prices.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3
Posted 18 January 2013 - 08:50 AM
Actually there is only one difference, the new plastic/?nylon rear bearing insert.
The new models use the second kit, it has a slightly thicker shoulder on the insert and slight larger diameter of the shoulder.
And one other unimportant difference, (that I just noticed by reading the parts descriptions), the newer model kit the ground strap slips thru the slot and it retained by one of the bearing holder mounting screws. The older model uses a separate stamped metal nut to hold the ground strap onto one of the mounting screws.
Eureka, CA 95501
