GE PSC23MGMB BB Refrigerator compressor not starting
motherboard start relay
6 replies to this topic
#1 mrjtwright
mrjtwright
    Ikkō-ikki
  • 33 posts
  • Flavorite Brew:Samual Adams
Posted 18 January 2013 - 09:58 AM
Hi, I have an issue with a GE Refrigerator that has a compressor that won't start.  It began as an intermediate problem but now won't seem to fire up at all.  Both fans are running, I don't hear any clicking coming from either the motherboard or the start relay.  Resistance of the compressor is 4.8/4.8 & 9.6 (perfect by my understanding).  There is voltage at the relay but I only Read 48 VAC between Start and common and 48 VAC between Run and common wires.  Oh yeah, relay passes the shake test also. Don't know how to test the overload.  I'm assuming muthaboard since only 48 VAC being delivered but wanted some pro opinion on the matter.
TIA
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,505 posts
  • Flavorite Brew:Killians Red
Posted 18 January 2013 - 10:06 AM
Pull the motherboard and look for burned solder joint on compressor relay...it will be pretty obvious...
#3 mrjtwright
mrjtwright
    Ikkō-ikki
  • 33 posts
Posted 29 January 2013 - 11:59 AM
Had to look twice on this one.  Very slight blemish but apparently enough to cause intermittent issues.  Thanks for the help.  I know this relay burn is common on these boards but what is the failure when the ice dispenser quits, lights dim & evap fan peters out? is that also related to the relay burn?
Edited by mrjtwright, 29 January 2013 - 12:00 PM.
#4 Comstock_Services
Comstock_Services
  • 462 posts
Posted 29 January 2013 - 12:05 PM
I have had issues in the past where, Evap fan would putter out or slow down and speed up, linked to the board in the past. I haven't seen a GE fridge in a while though.
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,505 posts
Posted 29 January 2013 - 03:09 PM
DC power supply on the board is crapping the bed...
  • 24,698 posts
Posted 29 January 2013 - 04:22 PM
Reminds me of a comic book I used to read...
#7 mrjtwright
mrjtwright
    Ikkō-ikki
  • 33 posts
Posted 29 January 2013 - 06:56 PM
Is that a GE Service Manual ?
