Jenn Air E33658
Patricio
Manual or Tech sheet for E33658.  Complaint oven does not work, most likely a defective element.  In case it's not, be prepared that's what I say.
  • Replies 1
  • Patricio
E33658 is an ID number but not the model number.
maybe SVE47xxxxx
