Sign in to follow this
Followers 0
dcvh
Whirlpool PIG # wtw4850xq0 a real mess
11 posts in this topic
Pig died real angry. After diagnostics I turned it on side to find belt cover destroyed, belt destroyed, shift actuator destroyed, agitator pulley stripped/destroyed, plastic motor drive pulley destroyed. With limited funds I replaced all including new imotor drive that came with metal pulley. (They knew about this sorry-ass engineered motor drive early-on but I'm screwed cause I'm 5 weeks out of warranty)
Fired it up with a regular wash to find everything normal till the rinse cycle. Rinse cycle starts filling then stops filling after 15-20 sec and goes straight to spin cycle. It does this with all the wash cycles EXCEPT the rinse&drain cycle which works normal (fills, agitates, drains)
I've recalibrated, ran auto test and fault/error code test 5-6 times all are normal. Unsure where to look for prob...wiring, harnesses, main control board, maybe new actuator is bad, optical sensor? I'll explore any and all ideas. WP engineers=Mickey Mouse.
No error codes
When a major breakdown occurs and then a different (new) problem occurs after the fix, first recheck your work. Second, because the problem is not being "sensed" with an error code, I would check the wiring harness and connectors. Remember that the main control cannot sense the error unless it is indicated by a signal. The lack of signal--voltage, resistance, etc--may indicate the problem--indirectly-- when an error code is not registered on the control board.
Will check wiring. ..let you know results
depending what settings you have it set too it is working normaly, these washers dont always do a full fill rinse, what you are describing could be a spray rinse
Have it on Regular wash setting which is full rinse not spray rinse...it completes WASH then starts RINSE filling then stops after 10-15 secs then skips directly to SPIN cycle...LED RINSE light does not come on...LED'S go from WASH to SPIN
SH2 SH2
"Have it on Regular wash setting which is full rinse not spray rinse"
My bad...REGULAR WASH is spray rinse...I'm guilty of not RTFM. However, problem remains RINSE cycle is completely skipped.
BTW does SH2 happen to stand for SIlent Hunter 2 ?
i knew the normal cycle used a spray rinse but i did not want to argue, as far as your problem i am at a loss, have worked on a lot of these and never seen this problem. and no im not silent hunter
Thanks SH
I haven't got to testing wiring and harnesses yet
Removing these harnesses is nightmare. Depressing release tabs with my fingers does not work. It takes putty knife/screw driver 10 min each and lotsa luck. (More brilliant WP engineering). Any suggestions?
Try a 1/4" drive socket, like maybe 3/16", and push it on the back side to compress the tabs on the harness retainers. Try other sockets to get the size right.
Did you try the test that allows you to see if the basket position sensor is working? I've worked on over a 100 of these things and never seen your current problem. It's not siphoning out the drain is it?
Nick
Followers 0
