Dacor Oven, I can't find the model #?
7 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 239 posts
  • Flavorite Brew:Root Beer
Posted 19 January 2013 - 09:03 PM
This Dacor seems like it has a control panel issue.  A weird pattern or error code stays on the panel (see attached photo) and the oven won't turn on, it acts like it will, then shuts off after a few seconds.  Any clues?  And where would I find the model #?
#2 kdog
    RoughShod
  • 7,428 posts
Posted 19 January 2013 - 09:16 PM
Pretty Much Anything you've ever wanted to know, but were afraid to ask is available in the PotLuck Supper here: http://appliantology...chnical-manual/
#3 RegUS_PatOff
  • 30,192 posts
Posted 19 January 2013 - 11:02 PM
look for the tag inside the oven, on the frame, once you open the oven door.
Cooktop looks like a
SGM304S
and Oven looks like
DO130
EOR130
MORS130
#4 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 20 January 2013 - 12:50 AM
Look inside left wall, or, through grill.
Edited by tpoindexter, 20 January 2013 - 01:07 AM.
Test
#5 AlexM
AlexM
    Sōhei
  • 239 posts
Posted 20 January 2013 - 08:08 AM
Thanks, I will head back and let you know what I find...
#6 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 20 January 2013 - 10:52 AM
Fyi...this tag is directly is the airway behind the grill under the control panel that'll
pulls the cooling air in...many times i have found these tags so covered with dust and grease, they were illegible till wiped off...
Edited by KurtiusInterupptus, 20 January 2013 - 10:55 AM.
#7 AlexM
AlexM
    Sōhei
  • 239 posts
Posted 23 January 2013 - 08:54 PM
I got the model# EORS136SCH (it was were you said, on the left side).  So the oven, convection, bake actually work, I didn't realize you need to press start before 5 seconds or it will shut off.
The display panel still has wierd readings, nothing that makes sense, like F1 or anything like that.  I pulled up the service manual and didn't seem to find this excact model number, so I got a little spooked regarding testing.  I couln't get the main mother board to look like the mother board in the manual?
I'm thinking this is the touch pad and control board? one or the other?  Thanks for any input you may have.
#8 RegUS_PatOff
  • 30,192 posts
Posted 23 January 2013 - 09:18 PM
http://appliantology...r-service-info/
