Kenmore Elite HE5 Dryer with F01 code, (no model# at this time)
3 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 241 posts
  • Flavorite Brew:Root Beer
Posted 20 January 2013 - 08:12 AM
I'm heading out to look at this dryer and the customer can't seem to find the model number.  I've attached a photo of the unit, if that can give any clues?  Not sure what the F01 error code might be?
#2 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
  • Flavorite Brew:yeunling
Posted 20 January 2013 - 08:49 AM
main control error code
#3 RegUS_PatOff
  • 30,299 posts
Posted 20 January 2013 - 10:37 AM
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
* Unplug or turn the circuit breaker off for 30 seconds
* Reconnect the unit to the power source
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display
* Start a short cycle to check the operation by pressing and holding the start button until the machine starts.
You may be able to clear this code by unplugging the washer for 5 minutes.
http://www.repaircli...R=154&N=1203065
Main-Control-Board-W10110641-00714220.jp
#4 AlexM
AlexM
    Sōhei
  • 241 posts
Posted 20 January 2013 - 04:30 PM
Just got back from visiting this dryer and got a model# 110.870866601
does someone have a manual available, Thanks.
I did the test and couldn't get it to indicate PF, and it looks normal intell you start it, then it goes to the F01 error code...?
Still thinking control board?
