Maytag SE 1000 will not agitate
Washer will not agitate
40 replies to this topic
#41 Budget Appliance Repair
  • 4,030 posts
Posted 22 February 2013 - 08:20 AM
The upper tub bearing is a bushing set up, (pre-lubed nothing more needed).
The lower spin bearing above the brake pak should be a sealed bearing and not need any other lube either.
The thrust bearing above the transmission pulley needs some regular auto heavy duty wheel bearing grease.
William Burk (Willie)
Eureka, CA 95501
