Maytag model mvwc6esww1
2 replies to this topic
#1 josh_am1
josh_am1
  • Chief Appliantologist
  • 19 posts
Posted 22 January 2013 - 03:39 PM
Washer is dead. Will not fill, spin...nothing. Does have power. Replaced timer, didnt do it. Does the control board (w10104800)that plugs into the timer control this. I thought it was a soak control. My other option would be water temp/pressure switch w10248240. Any help would be appreciated.
Josh
#2 Wingerman
Wingerman
    Yamabushi
  • 77 posts
  • Flavorite Brew:Cuervo Silver and Lemonade
Posted 22 January 2013 - 06:51 PM
The water temp/pressure switch is a notorious failure on this model. Trace the power from the wiring diagram with a meter to make sure power is going where it should.
  • 24,199 posts
Posted 23 January 2013 - 10:09 AM
ATC Switch ==> http://www.repaircli...mber=MVWC6ESWW1
Temperature-switch-W10248240-01093342.jp
