GE Profile 42 & 48 Built in Refrigerator PSB42......
3 replies to this topic
#1 dimitri77565
dimitri77565
    Ikkō-ikki
  • Chief Appliantologist
  • 54 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 23 January 2013 - 11:27 AM
Just replaced the Freezer evaporator fan motor, (for the 1st time) .  The factory manual, you can find in this site, shows the evaporator unit dropped
then turned upside down & to hang with a wire from top condenser.   I don't know about YOUR copper tubing skills , but if you force the tubing you will
more than likely get a kink.   I just dropped it far down enough to get a screw driver in between & rested it on the top  shelf.  Yes it was hard but i am used to working
blind or limited visibility.  Even then I had to be careful in putting it back in.  Keep in mind where all the wiring plugs go & how they are routed.  I have the CD which is
the same as the download at this site.  Had it on my iPad , old timers need help these days.
  • 24,364 posts
Posted 23 January 2013 - 12:52 PM
Good tip, Dimitri.  Did you happen to take an purdy pitchers?
#3 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 23 January 2013 - 04:38 PM
Edited by tpoindexter, 23 January 2013 - 11:55 PM.
Test
#4 dimitri77565
dimitri77565
    Ikkō-ikki
  • 54 posts
Posted 23 January 2013 - 11:33 PM
I should have, forgot camera was in truck.  LOL could have had a v8!  I promise next I will.
Edited by dimitri77565, 23 January 2013 - 11:34 PM.
