Kenmore front load 41744252500 won't go into high speed spin
2 replies to this topic
#1 Mufasa
Mufasa
    Yamabushi
  • Chief Appliantologist
  • 81 posts
Posted 23 January 2013 - 06:34 PM
Washer won't go into high speed spin. What to look for?
Your help is much appreciated!
#2 nickfixit
nickfixit
  • 1,965 posts
Posted 23 January 2013 - 06:47 PM
broken or cracked shock mounts, door switch would be first try.
#3 RegUS_PatOff
  • 30,255 posts
Posted 23 January 2013 - 07:11 PM
during Spin, is the Door locked ?
Is it really locked ?
If so, then un-plug Power Cord from Wall Outlet.
Can you then open the Door right away ? (bad Door Latch Assembly)
OR only after a few minutes ?
http://www.repaircli...R=154&N=1531974
Door-or-Lid-Latch-Assembly-131763202-012
The internal "wax motor" is bad ..
could be disassembled and replaced  ..
