herfdog
This bar fridge clicked at times but I haven't been able to hear it. apparently the noise is from the damper. Also there is ice build up on lower rear wall of freezer pushing through campartment seal and some frost around damper near icemaker and on the rear of ice maker. Is this a damper issue? Is there a way to test damper? Can I get a service manual for this unit?
Thanks
  • Replies 1
  • herfdog
