Thermadore model help
12 replies to this topic
#1 cdoremus
cdoremus
  • 7 posts
  • Flavorite Brew:sierra
Posted 25 January 2013 - 10:56 AM
I recently bought a home with a thermadore 48 inch range that has a few issues.  I am unable to find a model number so I can buy parts.  There is a sticker on the back with a serial number and a test date of 2000.  The problem with the stove are as follows:  Left 2 burners wont work on xlow.  Small oven & light inside not working. Need new back splash as we added a pot filler and the old one is to high.  I   did call Thermadore but they were no help since i could not provide a model number. Please help as I need to get this off my honeydew list..
Charlie
#2 RegUS_PatOff
  • 30,698 posts
Posted 25 January 2013 - 11:18 AM
model number may be near the left rear burner
#3 dimitri77565
dimitri77565
    Yamabushi
  • Chief Appliantologist
  • 61 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 25 January 2013 - 11:34 AM
Yes Sensei is right , remove the grates, its some where under them.  If not check behind kick plate.
#4 cdoremus
cdoremus
  • 7 posts
Posted 25 January 2013 - 12:01 PM
I removed the grates and they have a stamp on them 15-12-63 is that it?   I tried to get under the drip pans but it looks like I need a special tool to removed star burner assembly.  I guess if I remove the ront panel I could gain access to remove drip pans  Any other ideas?
  • 24,715 posts
Posted 25 January 2013 - 12:08 PM
That's a part number for a mica washer.  Your model number is something like PRG304US, PRG366US/364US, PRG484GGUS.
#6 cdoremus
cdoremus
  • 7 posts
Posted 25 January 2013 - 12:29 PM
after looking through online manuals the model that looks closets to mine is PRDS48/duel fuel.  If I use that model based on a picture what are the chances the parts will work?
#7 cdoremus
cdoremus
  • 7 posts
Posted 25 January 2013 - 12:33 PM
What pats would I need to repair the problem with xlow on burner and non working smal stove or how do I determine what the problem is?
#8 RegUS_PatOff
  • 30,698 posts
Posted 25 January 2013 - 01:05 PM
#9 cdoremus
cdoremus
  • 7 posts
Posted 25 January 2013 - 01:39 PM
il check that out  thank you Thermadore told me it wold be on the kick plate
#10 cdoremus
cdoremus
  • 7 posts
Posted 25 January 2013 - 09:04 PM
Found it  I have no idea why I didnt see it before.  Thanks guys!!!   Now any ideas on what the problem is with the small oven and the xlow on the burners?
#11 RegUS_PatOff
  • 30,698 posts
Posted 25 January 2013 - 09:53 PM
model number ?
#12 cdoremus
cdoremus
  • 7 posts
Posted 26 January 2013 - 08:56 PM
model number ?
Prd5486gdus
#13 RegUS_PatOff
  • 30,698 posts
Posted 26 January 2013 - 09:37 PM
Prd5486gdus
maybe
PrdS486gdus
this manual may be similar
http://appliantology...-dual-fuel-wok/
