Bosch SHE43f16UC won't drain
31 replies to this topic
#21 Samurai Appliance Repair Man
  • 24,345 posts
Posted 10 February 2013 - 04:04 PM
You need to blow through that discharge tube from the drain pump.  Looks don't count.  Don't be squeamish-- I do this all the time and I've only gotten diarrhea twice... or twelve times... or maybe a couple hundred... hell, I don't remember, I crapped those brain cells out long ago.
#22 telefunkenu47
telefunkenu47
    Kohai
  • 322 posts
Posted 13 February 2013 - 11:31 PM
oNCE HAD A PEICE OF BROKEN GLASS IN THE DISCHARGE HOSE,FROM PUMP TO DRAIN HOSE. ACTED LIKE A FLAPPER, SOMETIMES DRAINED , SOMETIMES NOT. TOOK ME FOR A LITTLE RIDE.JUST MY .02$.GOODLUCK!
Even root canal is easy...if you're a dentist...
#23 harringg
harringg
    Yamabushi
  • 64 posts
Posted 16 February 2013 - 01:30 PM
Time to call in the repair team.  It's been an overall slow process on my part, I was waiting for the terminal block to come from RepairClinic (and then find time to install it once it came), did that this morning, ran a quick wash and it counted down but nothing was happening (Start @ 32 Min, by 24 min, nothing in the tub), meaning no water was filling the tub.  Yes, water is turned on under the sink.
That being said, the pump is working again, I poured a glass of water in the dishwasher, cancelled the quick wash, and the water was pumped away.
Anything last minute to look for regarding the not filling with water issue before making a phone call to a local repair shop?  Was there another valve I may have closed on the dishwasher side that i forgot about?
Under sink: HW-Red Handle 1 (to sink, works), CW-Blue Handle1 (to sink, works), CW-Blue Handle tee'd to dishwasher (wide open, even tried "open/close" while waiting for the tub to fill in the event it was sticking).
#24 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 16 February 2013 - 01:40 PM
Sounds like a different issue now?
What fixed the problem of it not draining?
Did you blow through the discharge hose from the drain pump?
Test
#25 jumptrout
jumptrout
  • 1,142 posts
  • Flavorite Brew:Coors Light
Posted 16 February 2013 - 07:43 PM
Water will not fill if the door switch is bad or disconnected.
#26 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 16 February 2013 - 08:38 PM
Are you getting 110V to the valve?
Test
#27 suampman
suampman
    Sōhei
  • Chief Appliantologist
  • 161 posts
  • Flavorite Brew:redbridge
Posted 20 February 2013 - 08:59 AM
Harringg, Did you figure it out? I gots ta know.
#28 harringg
harringg
    Yamabushi
  • 64 posts
Posted 30 March 2013 - 03:32 PM
Sorry for the delay in response.  Things have been hectic.  Been washing dishes the "old fashioned" way.  Everything works now.
Quick overview.
1. Wouldn't drain
2. Replaced drain pump
3. Still wouldn't drain
4. Pulled dishwasher out
5. Checked float switch/float, all good
6. Pushed back into place
7. Would now drain, but wouldn't fill (did before pulling it out)
8. Sat for about one month not working on project
9. Called repair service
10. Red float rod was stuck (happened when pushing back in place apparently)
11. Repair serviceman moved that back into place, and left.  No charge
12.  All works again!
Unless there was something that was stuck in the drain line that got loosened by moving the dishwasher out, I did nothing other than replace the drain pump (and put the original one back in too and it still drained)  I've ran several full loads and everything works great.
Thanks for everyone's assistance along the way!
One final question, where do these two pieces go back into place at?
#29 Samurai Appliance Repair Man
  • 24,345 posts
Posted 30 March 2013 - 09:49 PM
Hmmm, where've I heard that before? Lets see....
Your punchlist, please respond explicitly to each:
- In front of this assembly should be the float assembly with a gray plunger and red piston.  Move the gray plunger up and down a few times to make sure it isn't stuck in the up (flooded) position.
He probably lurks at these forums and read the solution right here! :dude:
#30 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 31 March 2013 - 12:41 AM
I went back and reread it earlier and started to repost it. :woot: :pint1:
Test
#31 telefunkenu47
telefunkenu47
    Kohai
  • 322 posts
Posted 31 March 2013 - 08:14 AM
I'll bet the drain hose was kinked where it went through  the wall. Been there done that.
#32 certified tech group 51
  • 1,988 posts
Posted 31 March 2013 - 10:45 AM
Took me about 40 minutes to find this little rascal .DSCF2017_zpsd120dd0e.jpg.....Pinched drain line..........Connection was to the right of the wall, behind the unit, pulled D/W out a bit, pushed drain/cancel and full flow of drain water..........
