Third heating element replaced in Samsung dryer...? Seems strange.
10 replies to this topic
#1 narodsobe
narodsobe
  • Chief Appliantologist
  • 12 posts
  • Flavorite Brew:Bernard
Posted 27 January 2013 - 11:33 AM
Posting a ponderable for you all on a fine Sunday.
Have Samsung DV328(AEW-XAA). Last year (January) I replaced the heating element. Ten months prior to that my spouse replaced the heating element. When I did it I can affirm that the heating element that I pulled out of the unit was indeed fried and there was a break in one of the coils.
Today, no heat in the dryer. Already planning the day tomorrow to pick up a new heating element.
But really, here is the ponderable: what is the likelihood that you'd need to replace a heating element three times in this type of frequency? I only have one child, so it's not like I'm doing laundry for a football team here.
My question is then: Am I putting tape on a situation where the heating element break is the manifestation of a problem, but not the real problem? If so...what's your guess on the source (correct power to the unit is my thinking).
Thanks!
Tamara
Tamara in Walburg, Texas
at
Bad Dogs Farm
#2 RegUS_PatOff
  • 30,698 posts
Posted 27 January 2013 - 11:47 AM
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
 $ 2.99 sometimes on sale
#3 narodsobe
narodsobe
  • 12 posts
Posted 27 January 2013 - 01:07 PM
Yes, I was just about to do that because I see that this is a perennial first Q for dryer would be fixiters. Actually have a new hook up kit that I've been wanting to install, because I'm a bit retentive. So I pulled off the old vent. Air flow is good at the house exit. I've left the new vent kit off for now. Turned on time dry (the programs haven't worked in a long time--I only time dry with this thing--and maybe that's an indicator of the rest of the problem). Temp is 71.3 F. So it's definitely not the heat level I would wish for.
The good news is that it's a great opportunity to vacuum out the back of that space--after a year it's definitely time.
And it's also time for me to figure out my next step. Thank you for posting this idea.
I've got the service manual also and am thinking about the thermistor/thermometer. Wouldn't the machine be throwing error codes, however (per the service manual), if something were amiss? (Mind you: I'm not super keen on replacing the PCB. I'm not that nuts. Well, at least I think I"m not.)
Time to watch some youtube in the spirit of trying to plan the next step. Sigh.
at
Bad Dogs Farm
#4 dimitri77565
dimitri77565
    Yamabushi
  • 61 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 27 January 2013 - 01:39 PM
when u replaced heating element  , was it just the element or the complete housing with the high limit thermostat & the thermal fuse?
If not, well  that's your problem. .  Probably your high limit or thermal fuse are not tripping in time to save the element
http://www.repaircli...5001119/1122501
#5 RegUS_PatOff
  • 30,698 posts
Posted 27 January 2013 - 01:51 PM
OR the Samsung version
DC97-14486A
http://www.repaircli...R=154&N=1795935
#6 narodsobe
narodsobe
  • 12 posts
Posted 27 January 2013 - 01:53 PM
I believe it was just the element. This part was what I used and it's the same as what was replaced prior to that.
Thank you for the next set of ponderables. I was thinking that there had to be something in addition / instead of the thermal element because of the issue in not being able to use any of the programs (only time dry), as well as the multiple thermal element replacements.
So a bad hi limit or thermal fuse can cause the thermal element to blow because...because they don't effectively regulate the heat and that means that the thermal element goes unchecked / probably burns too hot?
And so I want the whole thing then, the element (linked above) and the assembly...?
In that picture it appears that the element is encased inside. Even better.
at
Bad Dogs Farm
#7 dimitri77565
dimitri77565
    Yamabushi
  • 61 posts
Posted 27 January 2013 - 04:37 PM
Sensei , I goofed posted maytag element number . thanks for catching that!
#8 narodsobe
narodsobe
  • 12 posts
Posted 27 January 2013 - 05:59 PM
Thank you both for posting anything! I'm all set to get that assembly in the AM.
at
Bad Dogs Farm
#9 narodsobe
narodsobe
  • 12 posts
Posted 29 January 2013 - 10:20 PM
The heat works. There was indeed a snap in the coil of the element. Thank you both!
at
Bad Dogs Farm
#10 suampman
suampman
    Sōhei
  • 172 posts
  • Flavorite Brew:redbridge
Posted 29 January 2013 - 11:00 PM
Did you check your input voltage. Extra voltage, extra current, shorter element life. Just a thought.
#11 narodsobe
narodsobe
  • 12 posts
Posted 04 May 2013 - 08:53 AM
Three (four) months later, all continues to be well. I haven't got a multimeter but I've been interested in picking one up. Now have excuse. Thanks everyone!
at
Bad Dogs Farm
