Frigidaire front load washer FTF2140ES1 wash basin full before wash cycle starts?
3 replies to this topic
#1 MKeating42
MKeating42
  • 19 posts
  • Flavorite Brew:OIe Leghumper
Posted 27 January 2013 - 01:05 PM
Back again with a new puzzle for my old Frigidaire front load washer, model # FTF2140ES1.
Today, after sitting idle for two days (laundry day was Thursday), my wife says the wash basin was full when she started to put clothes in for a new load. A drain/spin cycle spun the washer out and it seems to be working fine now.
That reminded me that when I was fixing the wiring harness a few weeks ago, the same thing happened to me. I shrugged it off, rationalizing that I must have kept the dial on the "fill" test on the way to the "spin" test.
Any thoughts? Again, seems to be working fine, and it's only happened once since I put humpty dumpty back together two weeks ago.
#2 RegUS_PatOff
  • 30,299 posts
Posted 27 January 2013 - 01:14 PM
sounds like a leaky Water Valve ..
When you're done with the laundry, unplug the Power Cord from the Wall Outlet ..
In a day or two, check to see if there's any water in the Washer ...
http://www.repaircli...R=154&N=1154728
#3 MKeating42
MKeating42
  • 19 posts
Posted 27 January 2013 - 02:35 PM
Will do. Thanks!
#4 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 28 January 2013 - 12:31 AM
YOU HAVE A BAD WATER VALVE, REPLACE, AND U WILL HAVE NO WATER IN TUB THE NEXT DAY
Also tagged with one or more of these keywords: Frigidaire, front load washer
