Whirlpool Washer
5 replies to this topic
#1 ApplianceDoctor
ApplianceDoctor
  • Chief Appliantologist
  • 19 posts
Posted 28 January 2013 - 07:08 PM
I have a Whirlpool washer M# WTW57ESVW0 Unit has Auto Load Sensing Switch instead of the old style pressure switch. When you set the timer to fill with water, unit starts filling and agitating at the same time. I personally think the Auto Load Sensing Switch is bad. Does anyone out there have any input on this problem? How can I get a service manual for this washer?
#2 Strathy
Strathy
    Kohai
  • 381 posts
  • Flavorite Brew:DP.
Posted 28 January 2013 - 07:29 PM
It is the load sense switch for sure. Change it out and you'll be good to go. Changed 8 or 10 of them for this symptom.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#3 RegUS_PatOff
  • 30,188 posts
Posted 28 January 2013 - 08:42 PM
... It is the load sense switch for sure. Change it out and you'll be good to go.
I agree
http://www.repaircli...R=154&N=1550760
#4 ApplianceDoctor
ApplianceDoctor
  • 19 posts
Posted 28 January 2013 - 08:46 PM
Thanks for all your help. You guys are good.
#5 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 31 January 2013 - 12:19 AM
REPLACED MANY, ANOTHER SIGN IS WHEN IT STARTS FILLING 4 A FEW MINUTES, AND THE UNIT DOES NOT AGITATE 4 A FEW SECONDS TO GET CLOTHES WET 2 PROPERLEY SENSE THE WATER LEVEL
Edited by LIONL56, 31 January 2013 - 12:27 AM.
#6 suampman
suampman
    Sōhei
  • 153 posts
  • Flavorite Brew:redbridge
Posted 31 January 2013 - 10:11 AM
I would just like to add a suggestion. Reseat all the console plugs and try the machine. I had a centennial washer doing the exact same thing, and thought I would try this, because on the cnc machines I used to work on, many times it would work. It did work and the machine is still working beautifully after three months. Something to do with electromagnetic flux I suppose. In and out fast and a very happy customer.
