Frigidaire Refer BFHS2611LM1
8 replies to this topic
#1 btenpin
btenpin
  • Chief Appliantologist
  • 13 posts
  • Flavorite Brew:Seagrams
Posted 29 January 2013 - 07:39 AM
We were called to this unit complaint no ice or water from dispenser.  Noted a flashing #2 in display water resivoir frozen looking through Frigidaire info that can find but not finding this Model.  Unit is fairly new 2 years old aprox any links to tech info appreciated.
I am assuming thermister issue ?  But you alll know what happens when you assume
  • 24,208 posts
Posted 29 January 2013 - 12:24 PM
Where are you seeing the flashing "2" in the control display: in the FF section or on the dispenser board?
Some light reading for you:
Frigidaire dispenser info (nothing with the error code "2"): http://appliantology...er-relay-board/
This manual should apply to your unit:  http://appliantology...-controls-2007/
#3 RegUS_PatOff
  • 30,198 posts
Posted 29 January 2013 - 03:38 PM
BETA CODES
'2'  FLASHING - OPEN THERMISTOR
'3'  FLASHING - SHORTED THERMISTOR
'4'  DAMPER ERROR
'HI'  HI TEMP
'd F' MANUAL DEFROST
240389639.pdf  < repaired link  :whistling:
Edited by RegUS_PatOff, 30 January 2013 - 10:56 AM.
repaired link
  • 24,208 posts
Posted 29 January 2013 - 04:10 PM
240389639.pdf
Ruh-row...
Invalid or Deleted File.
The key you provided for file download was invalid. This is usually caused because the file is no longer stored on MediaFire. This occurs when the file is removed by the originating user or MediaFire.
Still have questions, or think we've made a mistake? Please contact support for further assistance.
#5 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 29 January 2013 - 05:54 PM
Ruh-row...
Must be fixed now cause it worked for me.
Test
#6 btenpin
btenpin
  • 13 posts
Posted 30 January 2013 - 07:48 AM
I got a Frigidaire error code guide which shows what you saying flashing 2 in Ffood display indicating open thermister.  We have thermister on order hopefully that takes care of it
btenpin
  • 24,208 posts
Posted 30 January 2013 - 08:54 AM
Weird. Still not working for me.
#8 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 30 January 2013 - 09:07 AM
Regs link:
Edited by tpoindexter, 30 January 2013 - 09:16 AM.
Test
  • 24,208 posts
Posted 30 January 2013 - 10:03 AM
Regs link:
That worked.  Domo, tp!
