NOTICE!
The following post is NOT to be construed as an attempt to educate or teach fellow technicians and DIYers---on troubleshooting an LG dishwasher!
If you're offended at having an LG trained tech explain how to diagnose & repair problems/faults with LG dishwashers---leave this site IMMEDIATELY!
<sorry couldn't resist/private joke>
<<<I have an LG Dishwasher. Model # LDF9810ST with no display. No response to any selections on keypad. I have power to the main PCB.>>>
On the MAIN BOARD---there's a large *yellow plug*.
Pull off this plug and check for 120 volts in the *plug*---if present---replace the MAIN BOARD.
LDF9810 models built **before** August 2007----->Main Board EBR38144401 (Serial Number range 806KW and lower)
LDF9810 models built **after** August 2007-------->Main Board EBR38144406 (Serial Number range 807KW and higher)
If there's NO power at the *yellow* plug...
Pull the *pink* plug off the NOISE FILTER and check for 120 volts in the *pink* receptacle on the Noise Filter (not the pink plug).
If no power--replace the noise filter.
