Clearing condensate drain in Whirlpool-built Maytag french door fridge mfi2670xem0
9 replies to this topic
#1 Sunlight Appliance
Sunlight Appliance
    Yamabushi
  • 70 posts
  • Flavorite Brew:Matcha Green Tea
Posted 29 January 2013 - 05:46 PM
I watched the Samurai's awesome video with the steamer and I have also ordered that exact same steamer.
My question is, after melting away all the ice and clearing the drain, how do you insure that this clog will not happen again?
On some defrost heaters you can do the copper wire trick where you zig-zag some thick wire along the water tray and down the drain a little. However, on this model the design is prohibitive of this trick.
Thank you in advance!
A little sunlight, a little cholesterol, and you'll be good to go :cool:
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,750 posts
Posted 29 January 2013 - 07:06 PM
You may not be able to zig zag wire throughout the tray but you can still drop a wire down the tube after you put a little water and baking soda in it.. This is normally all I do anyhow unless I have a serious repeat frozen tray problem.  Now remember, the Samurai has all kinds of special powers and magical resistance us mortals don't have.  That's why he doesn't catch gookitis from sucking the disgusting gookus crud found in condensate  drains. He even has a special tube he keeps in his toolbag just for sucking gookus!.   :puke:
I power steam it open with a hose attachment on my steamer that fits down the tube.  I can't catch gookitis, typhus or the monkeypox that way.   BTW with this model, make sure to check  rubber gasket connected to the drain tube under the fridge. They always cause problems.  They make a replacement but I have recently done Master Kdog's v-cut modification with great success.
Edited by DurhamAppliance, 29 January 2013 - 07:17 PM.
#3 Sunlight Appliance
Sunlight Appliance
    Yamabushi
  • 70 posts
Posted 29 January 2013 - 08:15 PM
HA! I was wondering about that!
Can you link this thread to Kdog's v-cut modification?
#4 kdog
    RoughShod
  • 7,428 posts
Posted 29 January 2013 - 09:01 PM
http://appliantology...l-refrigerator/
Edited by Samurai Appliance Repair Man, 29 January 2013 - 09:17 PM.
Added embedded video.
#5 Strathy
Strathy
    Kohai
  • 382 posts
  • Flavorite Brew:DP.
Posted 29 January 2013 - 11:01 PM
http://neighboursapp...king-water.html
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#6 Sunlight Appliance
Sunlight Appliance
    Yamabushi
  • 70 posts
Posted 30 January 2013 - 01:22 AM
Thank you for this very well done article link!
So, trimming off just a little doesn't cause too much warm air to be drawn up into the freezer?
Where exactly on this grommet would Kdog's v-cut go if I wanted to do that instead?
#7 kdog
    RoughShod
  • 7,428 posts
Posted 30 January 2013 - 01:46 AM
#8 Strathy
Strathy
    Kohai
  • 382 posts
Posted 30 January 2013 - 09:42 AM
I worried about warm air migration when I first started cutting these so I went back to the first several that I did to check.  There is no sign anywhere of increased moisture buildup ... the evap stays clear and the frost pattern completely normal.  Cutting them this way does not cause an issue.
I don't know that 'Kdog's v-cut' is ...  There are 2 types of rubber grommets - the one I showed in the post is the short one: those I cut the end off as I showed.  The other one is a longer one and tends to get sticky causing the flaps to stick together.  Those ones I notch out in the middle so that the middle part of the flaps are basically gone.
The basic idea is to prevent junk from blocking them or to prevent them from sticking together and keep the water flowing - a simple solution to a dumb problem.
  • 24,347 posts
Posted 30 January 2013 - 10:06 AM
Moved kdog's reply to Sunlight's question which was posted in the wrong topic...
The area marked with the arrow - if you install the newly designed duck bill, cutting the v should not be necessary as it is redesigned.
#10 DurhamAppliance
    Sho' Nuff Chozin
  • 1,750 posts
Posted 30 January 2013 - 10:08 AM
Ran into two Lg's the other day with the same problem. One had a flap on the end of the grommet and it was wedged shut against the bottom of the drain pan. I shortened the tube a bit bit but left the flap intact . The other had a cylindrical grommet with a slit on the bottom side. Sort of like a slit cut into a barrel. Could not make a Kdog cut so I did a Strathy cut.
Btw if the new duck bill design is the longer one as depicted in the thumbnail, I have found the same problem. I put a Kdog cut in it as well
Edited by DurhamAppliance, 30 January 2013 - 10:19 AM.
