Neptune DC MCG8000AWW
24 replies to this topic
#1 yell0w_lantern
yell0w_lantern
  • 11 posts
  • Flavorite Brew:Birch Beer
Posted 29 January 2013 - 10:49 PM
Neither the upper nor lower part of the unit will start.
The lights come on in each bay if the respective door is opened. The control panel lights up and all the buttons cause a beep when pressed. The green light next to the Time Dry button does not light up and if pressed when the dryer is completely off then the Sensor Dry mode is activated. Pressing the Start button for either the upper or lower dryer turns off the entire dryer without any sort of pretense at starting - no rumble, no sound of turning over, nothing at all.
A service man was here and tried replacing the circuit board but to no avail.
My guess is a fuse of some sort.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 29 January 2013 - 10:59 PM
Which circuit board?  there's one in the control panel and one in the base of the machine in the very bottom, the bottom one usually goes bad because of water leaks in basements.
Scott Wolf
#3 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 29 January 2013 - 11:30 PM
I know for sure it was in the control panel.
#4 kdog
    RoughShod
  • 7,428 posts
Posted 30 January 2013 - 01:57 AM
http://appliantology...ce8000-mcg8000/
#5 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 30 January 2013 - 12:41 PM
Thanks for the manual. It does not specifically say where the thermal fuses are.
#6 RegUS_PatOff
  • 30,262 posts
Posted 30 January 2013 - 01:02 PM
parts diagrams
http://appliantology... MCG8000AWW.pdf
#7 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 30 January 2013 - 02:43 PM
parts diagrams
Get an error when you click this link
Test
#8 RegUS_PatOff
  • 30,262 posts
Posted 30 January 2013 - 02:53 PM
what error ?
works for me ...
#9 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 30 January 2013 - 03:25 PM
I get a File Not Found error, too.
#10 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 30 January 2013 - 03:29 PM
Sorry, we couldn't find that!
is the message I get
Test
#11 RegUS_PatOff
  • 30,262 posts
Posted 30 January 2013 - 05:30 PM
OK, I added it to the
MCG8000AWW service manual collection
#12 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 30 January 2013 - 06:35 PM
Perfect!!
Test
#13 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 30 January 2013 - 10:11 PM
Thanks!
[UPDATE] I checked my thermal fuses, high limit thermostat, and flame sensor for continuity and they were fine. The thermistor registers 12kOhms and no continuity, which, from what I read, sounds normal.
So would it be the relay then?
Edited by yell0w_lantern, 31 January 2013 - 12:20 AM.
#14 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 02 February 2013 - 09:16 PM
Okay, replaced the relay and no change. I had heard that motor also should be replaced when a new relay is put in but the motor won't be in until Monday.
#15 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
  • Flavorite Brew:yeunling
Posted 03 February 2013 - 11:35 AM
Are we sure the first repair man actually replaced the board in the console?
#16 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 03 February 2013 - 02:47 PM
He replaced it and the problem persisted so he swapped the old board back in and did not charge me.
#17 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
Posted 03 February 2013 - 02:51 PM
do these have a separate membrane touch pad or is it all one board in the console
#18 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 03 February 2013 - 05:21 PM
the control panel is separate from the board; yes, it is membrane style.
#19 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 04 February 2013 - 12:33 AM
The problem is probably the main control board in the base of the machine.  http://www.repaircli...Number=31001561
This is the last time I'm going to advise you that this is the problem.
Edited by Scottthewolf, 04 February 2013 - 12:35 AM.
Scott Wolf
#20 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 04 February 2013 - 08:30 AM
I was under the impression it is also called, "the relay". I already took your advice and replaced it as I said above. So unless I got a bad component, it must be something else.
