Neptune DC MCG8000AWW
24 replies to this topic
#21 RegUS_PatOff
  • 30,216 posts
Posted 04 February 2013 - 09:12 AM
... I was under the impression it is also called, "the relay".
It's called the Relay Board Assembly ..
the Relay is just one electrical component on the Board that could be replaced separately (soldered) ..
#22 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
  • Flavorite Brew:yeunling
Posted 04 February 2013 - 09:22 AM
so are we left with the membrane touch pad being bad?, not the main board and not the controller in the console
#23 yell0w_lantern
yell0w_lantern
  • 11 posts
  • Flavorite Brew:Birch Beer
Posted 05 February 2013 - 10:30 AM
That's what I'm wondering. Is there a way to test it with a multimeter or do I need more sophisticated equipment?
#24 RegUS_PatOff
  • 30,216 posts
Posted 05 February 2013 - 10:45 AM
... all the buttons cause a beep when pressed.
membrane would seem to be good
Did you run the *Pd Membrane Key Pad Utility as mentioned in the Service Manual ?
... Pressing the Start button for either the upper or lower dryer turns off the entire dryer
.has this Dryer worked OK up till now at this location ?
#25 yell0w_lantern
yell0w_lantern
  • 11 posts
Posted 05 February 2013 - 04:34 PM
No, I didn't run the key pad utility. The dryer came with the house. We bought the place about 1.5 years ago. One key on the panel has not worked correctly that entire time - the time decrease key on the lower dryer. Not starting began after I used the top compartment one night.
[UPDATE]
Since neither time up nor time down is working on the lower compartment I had to use the controls for the upper.
On Pd Membrane Utility: the lights next to time dry, sensor dry and wrinkle release stayed lit
Logic board test : Pass/Pass
Help Code List: LS and LE both came up
Diagnostic Code List: 8 displayed as the only value and selecting that with time up displayed 2 (on the display for the lower compartment) and 982.
Edited by yell0w_lantern, 05 February 2013 - 09:20 PM.
