Kenmore Range 790.94022600, Installed new terminal blocks.
8 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 240 posts
  • Flavorite Brew:Root Beer
Posted 30 January 2013 - 08:58 PM
So I installed two new terminal blocks on this range and it took a little bending of the burner ends to get them slid into the new terminals.  Now the customer called and said he can't get the burners in and out. I would like any suggestions on how to 'loosen' up this connection so they can easily clean the range top.  I think I used P/N 5303935058 for the terminal blocks.
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 30 January 2013 - 09:42 PM
Not sure why the customer is having problems. Are there any other variables to consider, such as new (and maybe incorrect) drip pans? Did you mount the receptacles the same way the original receptacles were mounted? Were the burners replaced as well?
#3 Tuco
Tuco
    Sōhei
  • 238 posts
  • Flavorite Brew:Tap Water
Posted 30 January 2013 - 11:04 PM
Did you use the old burner? I prefer to use a new burner with a new block when I can.
#4 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 30 January 2013 - 11:14 PM
Good"n"tight is the way they should be. :wink: Loosen em up and they will arc out. Try pulling them in and out about a dozen times.
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 31 January 2013 - 12:18 AM
I also recommend using the heavy duty blocks. They are porcelain and last much longer. Also easier to install as the wires are so well insulated that you don't use heat shrink tape. http://www.repaircli...12001676/400645
Edited by DurhamAppliance, 31 January 2013 - 12:21 AM.
#6 Budget Appliance Repair
  • 3,998 posts
Posted 31 January 2013 - 07:58 AM
I agree with Durham, those porcelain block ones are the only ones I use now, not that much more in price and a much better repair.
William Burk (Willie)
Eureka, CA 95501
#7 RegUS_PatOff
  • 30,216 posts
Posted 31 January 2013 - 08:20 AM
http://www.repaircli...?R=154&N=400645
http://www.repaircli...sp?R=154&N=2828
#8 Budget Appliance Repair
  • 3,998 posts
Posted 01 February 2013 - 08:35 AM
RegUS, Just in case you didn't know, those two are not interchangeable.
The top one is the most common standard receptacle used on almost all electric ranges.
The bottom one is a special GE only and will only work with the GE elements, they have a much wider metal plate between the two element legs.
Eureka, CA 95501
#9 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 07 February 2013 - 11:02 PM
A follow up...I went back today and istalled the porcelain  blocks and those are now the only ones I will use.  they work really well.  Thanks for all the help!
