Maytag washer MAV7700AWW transmission threads messed up
11 replies to this topic
#1 rolandvz71
rolandvz71
    Sōhei
  • Chief Appliantologist
  • 202 posts
  • Flavorite Brew:Sweet Sun Tea w/lemon
Posted 30 January 2013 - 09:30 PM
OK I found this washer and the tub bearing was shot. The seal nut broke then 3 of the 4 screws broke on the basket hub assembly. Tried to removed the basket hub assembly but was a booger to turn soooooo here I go grinding it off and well you guessed it I messed up some threads......now I have found this tool on line
http://www.deyparts....er_14922/474247
http://www.allapplia....asp?prod=14922
Why are they calling it a "Maytag Tube Thread Chaser" when it says...... "Designed to re-thread basket drive tube before reassembly on all model washers except Maytag"
Is that a type-O?
The tranny is good but the 4 starting threads on the tranny are a little shot......if this tool can help  me someone plz let me know.
To me---- it seems like it would work, but I want to know for sure before moving forward....and if this does not work----- does anyone know what die I would need to re-cut these threads?
Thx!
Edited by rolandvz71, 31 January 2013 - 09:08 AM.
#2 dimitri77565
dimitri77565
    Yamabushi
  • 61 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 30 January 2013 - 11:48 PM
You're either brave or work for an insurance. LOL
I have not done this since i quit AHS.
Most customers wont pay the price, such a piece of junk.
LOL I remember grinding away , sparks flying, dust LOL
#3 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 31 January 2013 - 09:00 AM
 Call me brave....no insurance work here-----I sometimes do work for people I know who can not afford new appliances so my labor is free....not looking for a laugh but a solution
Thanks!
Edited by rolandvz71, 31 January 2013 - 09:03 AM.
#4 Comstock_Services
Comstock_Services
  • 462 posts
Why would it not work? I'd spend the $20 before I ate the cost of a new tranny.
That tool looks like it would do the job, the other  way is to order an extra basket drive block and try to fix the threads with a file or a small dremmel tool.
Edited by Comstock_Services, 31 January 2013 - 09:07 AM.
#5 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 31 January 2013 - 09:15 AM
I have a new seal kit.....the new drive block will not screw in by
hand w/out stopping 1/2 a round into the threads.....I have tried a
small file no luck. No Dremmel tool to work with.....I will keep on it!
Thanks for the input!
#6 Comstock_Services
Comstock_Services
  • 462 posts
Posted 31 January 2013 - 09:23 AM
Sorry my ADD kicked in If you had an extra drive block you could use it to fix the threads on the transmission by forcing it in place, the block is aluminum, the tranny is steel cased, so you would mess up the threads in the extra drive block, it would be ok, as long as it fixed the threads on the tranny before cross threading the drive block. Hope this is coming across more clearly than my last post. I still think that that tool would work, as log as it wasnt for one of those amana spped queen clones.
#7 suampman
suampman
    Sōhei
  • 172 posts
  • Flavorite Brew:redbridge
Posted 31 January 2013 - 09:26 AM
It will work. It is just a die(as in tap and die)(harder and sharper than the shaft). Carefully start the thread chaser with some oil and make sure it aligns properly at the start of the threads. Take it down a couple of threads back it off and repeat until the threads are clean and straight. There are also thread files you can buy, but you must know your thread pitch and threads per inch. You could try a triangle file. I'd be real careful with a dremel tool. Good luck.
#8 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 31 January 2013 - 10:31 AM
OK will do.....I will see about getting the tool ordered today!
Thx all !
#9 dimitri77565
dimitri77565
    Yamabushi
  • 61 posts
Posted 31 January 2013 - 10:39 AM
A kit of die files is always good to have there are   8 different types per file , the 2 i have cover all threads but have them for over 20 years don't remember where i got them.
http://www.sears.com...=32-224791884-2
also tool supply stores?
And I am sorry for 1st post , did not meant to make fun of you.  But I use to do these jobs all the time still have bad taste in my mouth.
#10 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 31 January 2013 - 02:12 PM
Tell me about! The dust in the air made me to buy some dust masks....I am sure that stuff is not good for the lungs!
Thx for the input about the tools
No problem about the misunderstanding...
Edited by rolandvz71, 31 January 2013 - 05:27 PM.
#11 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 01 February 2013 - 06:23 PM
tool is on order....mean while I will try the file trick....
#12 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 19 February 2013 - 11:05 PM
sorry for the delay.....tool worked like it should! Another addition to my toolbox!
