whirlpool vmw washer, no model #
12 replies to this topic
#1 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 31 January 2013 - 10:28 PM
RAN DIAGS, NO CODES, START UNIT, FILLS, AGITATES PROPERLY, LED LIGHT NEVER GOES TO WASH, STAYS ON SENSING, VERY SLOW AGITATION,SPINS PROPERLY.  NEED ADVISE, THANKS
  • 24,289 posts
Posted 01 February 2013 - 08:06 AM
How can it not have a model number?
Check the splutch bolt.  There's a service bulletin on the bolt backing out ==> http://appliantology...etin-w10492393/
Here's the service manual ==> http://appliantology...raining-manual/
#3 Wingerman
Wingerman
    Yamabushi
  • 77 posts
  • Flavorite Brew:Cuervo Silver and Lemonade
Posted 01 February 2013 - 10:09 AM
Anytime you can't get a diagnostic code, suspect wiring problems. Working from memory, on the MVW and WTW models, there's going to be a potential loose/corroded wiring issue on the J2/J16 shifter and motor controls off the Main Control Board (MCB). Beyond that, to begin, check the shift motor relay on the MCB; then, Ohm out the Shifter motor (pins 1 and 2 off the J16 connector)--reading about 2K to 3K ohms. Look for burnt Motor triacs on the MCB; windings on the PSC motor should be in the range of 3 to 6 ohms. All for starts to ID a potential Shift Assembly problem.
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 01 February 2013 - 02:32 PM
Model number should be located under the lid in the back, very hard to see unless you have the lid part way open.
Scott Wolf
#5 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 01 February 2013 - 11:20 PM
CUST GOT UNIT FROM SCRATCH DENT WAREHOUSE, NO NUMBERS, WILL CHECK WIRING, ALLREADY CKD PULLEY, ACU,ETC, THANKS 4 ADVISE, WILL UPDATE.
#6 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 02 February 2013 - 01:38 AM
Model # tag missing means Whirlpool wanted the unit scrapped out.  It should not have been resold.
Scott Wolf
#7 certified tech group 51
  • 1,978 posts
Posted 02 February 2013 - 11:19 AM
Did you pay for this unit????    As Scottthewolf states, this is a 'stripped unit'........This unit when new, had previous attempts to be repaired..............Could not be repaired, so instead of spending more tech time on it , it was stripped of its label and was supposed to be sent off to be  junked/recycled...........  .
#8 RegUS_PatOff
  • 30,255 posts
Posted 02 February 2013 - 11:28 AM
could be actually a "good / running" unit, built from (new?) "scrapped" appliance parts.
How long ago did you buy it ?
Has it been running OK up till now ?
#9 sh2sh2
sh2sh2
    Sōhei
  • 212 posts
  • Flavorite Brew:yeunling
Posted 02 February 2013 - 07:20 PM
I have seen a few where the crappy lables fell off, luckily the customer had found it before it got lost, and im not talking on old ones, i have seen it on 2 vmw's
#10 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 03 February 2013 - 01:13 AM
I miss the old days when they were riveted on the machine.
Scott Wolf
#11 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 03 February 2013 - 05:31 PM
UNIT IS 10 M0NTHS OLD, SHE HAD STICKER ON IT WHEN NEW, SHE HAS OCD, CLEANING NUT, CLEANED STICKER RIGHT OFF, GETING REPLACED FROM W/P
#12 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 04 February 2013 - 12:42 AM
Lionl56,  please take your caps lock off when you post, typing in all capital letters is the internet version of yelling.
Scott Wolf
#13 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 04 February 2013 - 12:52 PM
Will give it a shot, will diag more indepth, thanks 4 ur imput
