Our Frigidaire front load washer, Model LTF2940FS1, will sometimes shut off when it is entering the spin cycle. Depending on the setting, it will shut off with 4 minutes remaining or 7 minutes. The water will drain but the machine just stops as if it has finished the wash. It does not do this all the time but when it does the clothes are soaking wet. Any ideas what might be causing this problem?
Frigidaire Washer Has a Problem in Spin Cycle
#1
Posted 03 February 2013 - 11:22 AM
#2
Posted 03 February 2013 - 11:37 AM
... will sometimes shut off when it is entering the spin cycle.
shuts OFF ? ... No lights, etc ?
Any Error Codes ?
#3
Posted 03 February 2013 - 08:40 PM
What I should have said is it stops as if it had finished a complete wash cycle. Yes, the lights are on and it has power. No error code.
Also tagged with one or more of these keywords: Frigidaire, Spin cycle, LTF2940FS1
