Frigidiare French Door - Ice Maker Not Working
43 replies to this topic
#1 SheltonRD66
SheltonRD66
  • 14 posts
  • Flavorite Brew:Blue Moon
Posted 04 February 2013 - 12:25 PM
Model # FPHB2899LF
Serial # 4A02114733
I have installed the upgrade kit for this ice maker, and still I am not getting any ice.
The icemold is in the left position with no water or ice in the mold. When I run through the troubleshooting guide, all of the tests check out ok.
I am not sure where to go next.
Any help would be much appreciated.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 04 February 2013 - 07:59 PM
http://www.emaservic...od_Icemaker.pdf
This may not appy to your model, seeing that the serial number run is not in this range.
Edited by Scottthewolf, 04 February 2013 - 08:02 PM.
Scott Wolf
#3 SheltonRD66
SheltonRD66
  • 14 posts
Posted 08 February 2013 - 12:37 PM
Checked the electrical connections and they all appear to be good.
Interesting part is that I can pour water into the ice mold and then turn on the ice maker. The mold will move into the left position and freeze the cubes. The harvest cycle is suppose to start when the ice mold temp drops to 28 degrees. I have checked the temp and it drops to 24 degrees, but will not start the process.
#4 Comstock_Services
Comstock_Services
  • 462 posts
Posted 08 February 2013 - 12:49 PM
It would be a good Ideal to check the thermistors, in the ice compartment? for proper resistance at the different temps. Scott I can't get your link to work.
Edited by Comstock_Services, 08 February 2013 - 12:59 PM.
#5 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 08 February 2013 - 07:05 PM
What's the temperature inside the freezer? Does it get colder than 24 F?
I think it needs to be around 16F for it to start cycling on it's on.
Edited by tpoindexter, 08 February 2013 - 07:14 PM.
Test
#6 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 08 February 2013 - 07:59 PM
I always tell people to check fridge temps first when there is an ice maker problem and I explain why. So they can remember for future references (but mainly so they call me as opposed to ignoring a failed ice maker), I tell them the ice maker can be like a canary in a mine shaft as it can let you know there may be a catastrophic major problem on the horizon... or a bad valve.
Edited by DurhamAppliance, 08 February 2013 - 08:02 PM.
#7 Budget Appliance Repair
  • 3,999 posts
Posted 09 February 2013 - 07:26 AM
That crazy piece of crap icemaker isn't in the freezer compartment.  It has it's own compartment in the refrigerator section with it's own evaporator and fan system along with a complete computer to run the show.
I'm sure glad I've never had to work on one of these yet, (If I get one I will refuse the job!!!).
I was amazed at that contraption the first time I had seen one, it was right where it belonged, in the scrapyard probably only a year or less old and scrapped out.
William Burk (Willie)
Eureka, CA 95501
#8 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 09 February 2013 - 04:22 PM
I will only work on them if it's an out of warranty call. I refuse to work on this piece of crap for Frigidaire's warranty rate of $60.
Scott Wolf
#9 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 09 February 2013 - 05:38 PM
 I didn't even look at the schematic and have never worked on one before neither. I will study it just to understand it....but I will refuse to work on it as well.
#10 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 09 February 2013 - 06:44 PM
I  went on a call for an icemaker not working. Got there an looked at it a liitle then told the customer I was sorry but they'd need to call someone else. I couldn't get away from it fast enough. That's the kind of ignorance that upsets me at engineers.
Edited by tpoindexter, 10 February 2013 - 07:31 AM.
Test
  • 24,296 posts
Posted 10 February 2013 - 07:05 AM
A couple of videos that may help:
Getting into Ice Maker Service Mode on the Frigidaire French Door Refrigerators
Troubleshooting No-Ice Complaints in Frigidaire / Electrolux French Door Refrigerators
#12 Budget Appliance Repair
  • 3,999 posts
Posted 10 February 2013 - 09:00 AM
So you're going to go get your engineering degree and computer science degree just to understand how that thing works then just throw all that learnin time way by not using it??? :kopkrab:  :kopkrab:
I got a headache just reading the tech manual telling how to run diagnostics on that piece of crap!!!!
I think Frickadaire locked a bunch of engineers in a lab and made them all drop a couple tabs of acid and said make us an icemaker that no one can figure out and that will never work right most of the time!!
Edited by Budget Appliance Repair, 10 February 2013 - 09:04 AM.
Eureka, CA 95501
#13 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 10 February 2013 - 01:14 PM
You mean you don't study things you find interesting even though there is no expected practical use for it? I find that just as perplexing. Guess that's why folks are different, huh? Heck, I study many things I expect never to use. Military strategy/history for example.. Hannibal's victory at Cannae... fascinating.. have several books on it but I don't plan on double enveloping anyone in the forseeable future. Last month I spent time learning and quizzing myself on US state capitals. No need for me to do that, visiting all of them certainly ain't on my bucket list. (now comes the "however" part)
However (see, told ya), studying something even tangentially related to what I do for a living, brings the added benefit of potentially increasing my value. Especially if I enjoy it. Who knows, there may be a brilliant concept hidden in there. If not, I will still learn something valuable. One learns from studying success and how to do something but one can learn just as much from studying failures and how not to do something.
Edited by DurhamAppliance, 10 February 2013 - 01:17 PM.
#14 Samurai Appliance Repair Man
  • 24,296 posts
Posted 10 February 2013 - 02:21 PM
Wisdom!  Let us attend!
I've come to realize that anything you learn just adds to your Life Bag o' Tricks.  All those Fun Facts to Know and Tell get dumped into that big cement mixer betwixt our ears, recombining with other stuff and WALLA! the next great Apple computer is invented, or the next great mouse trap is born.  Plus, continually learning new things, anything as long as it's new to you, is the single most effective way to keep from getting Alzheimer's.  And it's just plain fun.
On a more practical side, learning about new technology, even if it's poorly conceived and executed, can only have a direct benefit for us.  We're in the technology trade, mah bruvahs, and the more technology you learn, the more you gain insight into the good, the bad, and the ugly that's out there in the appliance world.  For Professional Appliantologists, that can only translate into higher earning potential.
#15 suampman
suampman
    Sōhei
  • Chief Appliantologist
  • 161 posts
  • Flavorite Brew:redbridge
Posted 10 February 2013 - 04:14 PM
AMEN! My inquisitive brothers of appliantology.
#16 Patricio
Patricio
    Kohai
  • 447 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 10 February 2013 - 10:55 PM
I study almost every early morning & evening about appliance repair (except when fishing then I study the water, birds, fish slicks, etc.)  I bone up on everything I am going to tackle today tomorrow & next week.   Makes me better prepared and a better service repairman. :thumbsup:
IgonFishn & Tight Lines
#17 Budget Appliance Repair
  • 3,999 posts
Posted 11 February 2013 - 07:49 AM
I guess it didn't really come thru very good, that was suppose to be a funny....  :wacko:
I totally agree with every you you said Durham!!!!
Eureka, CA 95501
#18 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 11 February 2013 - 08:55 AM
I think everyone knew that Willie. Ya gotta admit it was funny how it blew up on ya though. :woot:
Test
#19 Patricio
Patricio
    Kohai
  • 447 posts
Posted 11 February 2013 - 11:21 AM
You never know what you get when you open a box of chocolate. :turned:
#20 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 163 posts
  • Flavorite Brew:guiness
Posted 11 February 2013 - 01:27 PM
too many big words....
