Frigidiare French Door - Ice Maker Not Working
43 replies to this topic
#21 john63
john63
  • 1,411 posts
Posted 11 February 2013 - 02:21 PM
<<<too many big words....>>>
Actually every "big" word becomes quite small when they're known/understood :)
Some people are indeed very intelligent---and the use of "big" words is a natural.
Others use "big" words as a tactic to overwhelm an opponent during a debate/discussion. Much like Hannibal's double-envelopement strategy in war.
At times---"big" words are used to *conflate*---as a tactic (otherwise known as a "throwing a curveball")
These tactics are often employed by someone standing on uncertain or "shaky ground" during a robust debate (or has a weak hand so to speak).
Sorta like having a chat with a guy---who inexplicably switches to russian instead of english. <laugh>
Edited by john63, 11 February 2013 - 11:42 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#22 SheltonRD66
SheltonRD66
  • 14 posts
  • Flavorite Brew:Blue Moon
Posted 11 February 2013 - 04:11 PM
Thanks for the all the great advice, and rants! :rocker: If I had hair, I would be pulling it out by now as still no ice.
I checked the resistance on the thermistors. According to the chart in the service manual they are working. The Ice Mold is at 19 degrees, so it is cold enough that the harvest cycle should start.
I also checked the temps in the freezer and refrigerator compartments, 3 degrees and 38 degrees.
I have ran every test you can when in service mode, and they all come back as good.
The only problem I did find was that the IM evaporator fan was not running. Fixed the connection and it is working now.
Any other thoughts, other then target practice?
I may just opt to add an ice maker in the freezer compartment. If any body knows the correct model# for that, it would be appreciated.
#23 RegUS_PatOff
  • 30,698 posts
Posted 11 February 2013 - 04:42 PM
... The harvest cycle is suppose to start when the ice mold temp drops to 28 degrees.
Harvest cycle starts when the Mold Thermostat drops to +15F or colder,
but a higher temperature shouldn't prevent Fill
Did it pass the Water Valve Test ?
#24 SheltonRD66
SheltonRD66
  • 14 posts
Posted 11 February 2013 - 04:55 PM
Yes it does pass the water fill test.
#25 SheltonRD66
SheltonRD66
  • 14 posts
Posted 11 February 2013 - 05:01 PM
The 15 degrees is for the ice maker in the freezer compartment. I am working on the fresh food ice maker. Service manual states 28 degrees for the harvest cycle to start.
#26 tpoindexter
tpoindexter
    Sōhei
  • 245 posts
  • Flavorite Brew:Beamish
Posted 11 February 2013 - 05:12 PM
can you turn it down some to see if it starts?
Edited by tpoindexter, 11 February 2013 - 05:16 PM.
Test
#27 SheltonRD66
SheltonRD66
  • 14 posts
Posted 11 February 2013 - 08:05 PM
Turn the freezer down to - 6 degrees and the fridge to +33 degrees. Still no ice, but my beer is much colder now!
#28 kdog
    RoughShod
  • 7,433 posts
Posted 12 February 2013 - 12:54 AM
Macaroni
Marmelade
#29 Budget Appliance Repair
  • 4,032 posts
Posted 12 February 2013 - 06:54 AM
Did you put a thermometer in the actual icemaker box compartment to see what the temp is in the icemaker enclosure box?
It has it's own evaporator in this box and will be at a complete different temp then the refrig compartment or the freezer compartment.  This enclosure is basically a complete mini freezer inside the refrig compartment.
I don't know the history behind all the service upgrades to these units but from the bit I read around hear I believe it went thru 2 or maybe 3 service upgrades which involved replacing the computer/board that controls the icemaker, (I think that board is mounted behind one of the covers on the rear of the unit).
William Burk (Willie)
Eureka, CA 95501
#30 Comstock_Services
Comstock_Services
  • 462 posts
Posted 12 February 2013 - 11:02 AM
Were you able to check the thermistor on the Finger evap that goes inside the icemaker mold? Check it with a multi meter.
#31 SheltonRD66
SheltonRD66
  • 14 posts
Posted 12 February 2013 - 02:56 PM
Temp in the IM box is + 10 degrees.
I have the latest upgrade kit available with the new control board installed.
#32 SheltonRD66
SheltonRD66
  • 14 posts
Posted 12 February 2013 - 03:00 PM
I did this and I am getting a reading of 66.352, which according to the service manual equates to about -1 degrees.
#33 SheltonRD66
SheltonRD66
  • 14 posts
Posted 12 February 2013 - 03:05 PM
My guess is that the IM is working correctly, however something else is keeping it from turning on.
This refrigerator is suppose to go into a "Freezer Recovery Mode" if the freezer temp is +8 degrees warmer then the set point. At that point the IM will no longer make ice. So I opened the freezer door until this condition existed, however the IM test for this did not show it to be in "FRM".
Wondering if there is a communication issue between the main control board and the IM control board, or something along those lines?
#34 Comstock_Services
Comstock_Services
  • 462 posts
Posted 12 February 2013 - 03:48 PM
I'm no expert on these things by any means, but I thought there was only 1 board that had to do with the ice maker and its the main board on the bottom.
#35 SheltonRD66
SheltonRD66
  • 14 posts
Posted 12 February 2013 - 04:00 PM
The IM control board is on the back of the refrigerator. The main control board is underneath the frigerator.
I am probably less of an expert then you are!
With all the tests passing that are directly related to the IM, it just seems there has to be something else that is stopping it from running.
Going to give it a few more days of tinkering on it, and if it does not work I will be adding an icemaker in the freezer compartment. Luckily it is wired and plumbed for one.
#36 Comstock_Services
Comstock_Services
  • 462 posts
Posted 12 February 2013 - 04:17 PM
Sorry Shelton, I've worked on three of these and only been able to fix 2 of them so far. I just read that the fan wasn't running in the ice compartment, and you fixed that, Did anything change after that?
#37 SheltonRD66
SheltonRD66
  • 14 posts
Posted 12 February 2013 - 05:41 PM
No change after fixing the fan, other then the Ice Maker enclosure gets colder now.
#38 Comstock_Services
Comstock_Services
  • 462 posts
Posted 13 February 2013 - 10:01 AM
So if I'm correct the mold moves to the left after it fills, and then it sits (parked) at the evaporator and never moves from the evaporator, even after the cubes have formed in the mold? does this sound right?
#39 SheltonRD66
SheltonRD66
  • 14 posts
Posted 13 February 2013 - 12:50 PM
Originally it would never fill with water. It just moved into the left position and stayed there. Last night, all of a sudden, it made two batches of ice. The only thing I did yesterday was check the thermistor, and the tempature in the ice box, so not sure what woudl have changed that caused it to make ice.
Now it is how you have described it. Mold in left position, cubes are formed, and it stays there.
#40 Comstock_Services
Comstock_Services
  • 462 posts
Posted 13 February 2013 - 01:06 PM
then I would guess that it has something to do with the thermistor, even though you said it checks good, with your meter. It's possible that the board is not reading the proper input from the thermistor, so I would ask you to check the resistance of the thermistor at the ice maker control, on the back. This is just to once and for all eliminate the thermistor.
The basic principal is that the unit fills, makes the cubes, the thermistor senses the change in temp, and then the unit cycles the hot gas valve, and moves the mold to fill, The hot gas valve lets the evaporator warm up so that the cubes can drop, and fill the bucket, after the cubes drop the thermistor again senses the temp change and then shuts down the hot gas valve, and the process starts all over again.
BTW There are several repair kits for these IM, I just dont know the part numbers to order to get them going again. If someone was factory authorised they maybe could find and post the service updates, and that may help shed some more light on the subject.
