GE F/L WASHER
WCVH6800J1MS
8 replies to this topic
#1 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 04 February 2013 - 01:16 PM
Unit starts, pump runs, fills with a little water,rotates fills with again, then stops in mide cycle. Checked codes, e38, e23, e61,e60,e46. Did manual test test mode, found presure sw test not responding properly, checked presure hose, pr sw harness, ok. cycle tested, worked properly once, then same problem, 3 other service company came out prior, i don't give up easily, any ideas, thanks
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 04 February 2013 - 08:23 PM
The pressure switches on these have been problematic.  I would replace it .
Scott Wolf
  • 24,245 posts
Posted 04 February 2013 - 09:04 PM
Sorry, budrow-- didn't catch that model number...?
#4 RegUS_PatOff
  • 30,216 posts
Posted 04 February 2013 - 09:42 PM
in the sub-title  :wallbash:
WCVH6800J1MS
#5 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 04 February 2013 - 09:57 PM
After diag,that was my thought, didn't want to jump the gun on this one. Thanks to all u guys, will replace presure sw, will up date, thanks
Edited by LIONL56, 04 February 2013 - 10:01 PM.
#6 RegUS_PatOff
  • 30,216 posts
Posted 04 February 2013 - 10:06 PM
After diag,that was my thought ... will replace presure sw,
http://www.repaircli...R=154&N=2024606
#7 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 04 February 2013 - 10:09 PM
  • 24,245 posts
Posted 05 February 2013 - 09:46 AM
Before you replace the pressure switch, check the pressure tube for wear holes.  If present, they can make the machine act like the pressure switch is bad.  Many techs have been fooled by this...
Pressure tube ==> http://www.repaircli...er=WCVH6800J1MS
#9 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 11 February 2013 - 10:12 PM
Because of the on going problem, we decided 2 order, hose, presure sw, main board. WILL CHANGE PARTS IN THAT ORDER BETWEEN TESTS. PROBLEM GOING ON 2 LONG, WITH 2 MANY COOKS IN THE KITCHEN, THANKS 4 ADVISE, WILL UPDATE
