I'm sure this is easy for some...
RED4400VQ1
9 replies to this topic
#1 jkirksey1889
jkirksey1889
    Sōhei
  • Chief Appliantologist
  • 162 posts
Posted 04 February 2013 - 05:20 PM
Roper Dryer RED4400VQ1
This dryer would not do anything.  I figured this would be a thermal fuse issue, but not.  Of course I checked power, all good there.  I checked door switch and start button, all good.
I went to the timer and did not get 220v to the timer motor.  I got 120v from 1 of the 2 black wires (to ground) going to timer motor.  Found the schematic and disconnected the harnesses to timer.  T-F (at the setting I had it on had continuity (as it was supposed to).  On the schematic I saw 1M and 2M (switch that must be at the dryer motor) that would send the other 120 to the timer motor.
Bad motor??
Does the other leg of power to the timer motor come from the dryer motor?  That what it appears on the schematic if I am looking at it right.
Edited by jkirksey1889, 04 February 2013 - 05:23 PM.
#2 RegUS_PatOff
  • 30,266 posts
Posted 04 February 2013 - 06:30 PM
... that would send the other 120 to the timer motor.
only when the Drum Motor is running ...
When the Dryer is set to run a regular Timed Dry cycle...
and Door is closed ...
measure voltage to chassis / ground from each of the following connections:
each side of white Thermal Fuse (on Blower Housing)
each side of Start Switch
#3 jumptrout
jumptrout
  • 1,141 posts
  • Flavorite Brew:Coors Light
Posted 04 February 2013 - 07:31 PM
The timer motor operates on 120 volts not 220 volts.
The only component in the dryer that draws 220 volts is the heating element.
#4 jkirksey1889
jkirksey1889
    Sōhei
  • 162 posts
Posted 04 February 2013 - 08:01 PM
I thought the same thing but the timer motor said 230v on it.
Edited by jkirksey1889, 04 February 2013 - 08:11 PM.
#5 RegUS_PatOff
  • 30,266 posts
Posted 04 February 2013 - 08:08 PM
... I thought the same thing but the time motor said 230v on it.
yes, it's a 230v Timer on that model
#6 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 04 February 2013 - 08:12 PM
http://www.repaircli...0185972/1481701
I've seen these 230 Volt timers without a resistor to be the problem alot of the time, causing the dryer not to start at all.  Remove the timer from the control panel and shake it. If you hear rattling inside the timer, the timer is indeed your problem.
Scott Wolf
#7 jkirksey1889
jkirksey1889
    Sōhei
  • 162 posts
Posted 04 February 2013 - 08:16 PM
Are you thinking something could be breaking down under a load?  I'm not going back to the house.  I think the lady was expecting a repair with a total cost under 100.  Yeah I know.  I told her I would do a little more research because I was stumped but she didn't wanna spend to replace the drum motor or the timer.  I'm just curious as to what the problem may have been.  I'm thinking drum motor.
#8 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 04 February 2013 - 08:21 PM
The motors on these rarely go bad, the timers seem to be failing more and more lately. We didn't seem to have these timer problems as much back when they made in the USA. I see a made in China sticker on this timer.
Scott Wolf
#9 jumptrout
jumptrout
  • 1,141 posts
Posted 04 February 2013 - 08:42 PM
Reg....would you please send me the wire diagram on this dryer?
Obviously I need to catch up on current events.
#10 RegUS_PatOff
  • 30,266 posts
Posted 04 February 2013 - 09:34 PM
... Are you thinking something could be breaking down under a load?
... was expecting a repair with a total cost under 100.
... she didn't wanna spend to replace the drum motor or the timer.
... I'm thinking drum motor.
1) don't know without tests posted above
2) any part ordered from RepairClinic can be returned for a refund (less shipping) including installed electrical parts
3) don't know without tests posted above
4) don't know without tests posted above
Wiring Sheet - W10185979.pdf
Repair Part List - W10253726.pdf
