Cabrio washer. Just purchase seal only?
4 replies to this topic
#1 Garpy
Garpy
    Ikkō-ikki
  • Appliantologist
  • 27 posts
  • Flavorite Brew:Coffee
Posted 06 February 2013 - 01:48 PM
I hope this is the proper way to ask for this. I have looked elsewhere to no avail. I do many bearing repair jobs on a variety of machines and have found that purchasing bearings localy is a LOT cheaper than kits. I even found an LG guy that will sell me the seals that are only available to LG service guys.
Here is the problem, I can't seem to find JUST the seal for certain makes of washers.
I ask now, Is there a source here or does anyone know a source to purchase JUST the seal for the Cabrio washers. I don't want the kit #W10435302
Any help would be appreciated.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 07 February 2013 - 02:32 AM
Good luck with that if you don't want the kit, You will spend half a day getting the old bearing out, it's not worth the time and aggravation just to save a little bit of money.
Scott Wolf
#3 Garpy
Garpy
    Ikkō-ikki
  • Appliantologist
  • 27 posts
Posted 07 February 2013 - 10:27 AM
Thanks Scott
From the repair guide and videos It looks like whether I use my own bearings and find a seal or use a kit will be about the same amount of work. (bearings need to come out either way) If that's correct then I think it will be worth it. Off the shelf bearings run around $10.00 each and most seals that I can actually find run up to $15.00 so $35.00 compared to close to $100.00 makes it a doable repair.  I'm retired and have nothing but time. I rebuild appliances for low income families so I REALLY need to work at keeping cost down.
Thank you for your input
Edited by Garpy, 07 February 2013 - 10:37 AM.
#4 Skiter29
Skiter29
    Kohai
  • 315 posts
Posted 07 February 2013 - 08:05 PM
why dont u buy 1 kit then go from those to buy  your off the market ones
#5 nickfixit
nickfixit
  • 1,964 posts
Posted 10 February 2013 - 11:08 AM
Maybe you could re-use the old seal, try adding an o-ring, or o-rings, under the lip of the seal and fill the entire void under the seal with synthetic or marine grease. It would be cheap, might be a worthwhile  experiment.
Are you using the factory tool to press the bearings into place?
Nick
