I have a Kenmore Elite HE3 dryer. I've had it for about 10 years. At one point I had to replace a fuse in it as a dime had made its way into the interior and caused a bit of a mess when it arced. But other than that is had been working fine. I've recently moved it from the basement to the 2nd floor. The second floor has an outlet that used to have an electric stove. It is also three prong as was the one in the basement but one of the prongs has an L-shape which worked in the basement outlet but will not fit on the 2nd floor.
What is the best approach? I could pull the old outlet from the basement and rewire in place of the existing one on the second floor. Or is it easier to get a different plug and replace the existing one on the dryer to match up to the outlet on the second floor?
thanks
