Hot Samsung TAX4DNCWH mini fridge; relay and overload kit discontinued!
13 replies to this topic
#1 alexeinspruch
alexeinspruch
    Sōhei
  • 125 posts
Posted 06 February 2013 - 07:53 PM
OK, this sucks. Out at the horse barn we have a fridge in our saddle and tack room that suddenly croaked. I whipped it around and the compressor is hot to the touch but no action whatsoever going on.....I pulled the relay and overload and looked them up here at Repairclinic:
http://www.repaircli...ed-System-Parts
The overload rattles when you shake it. Nothing smells burned. Relay seems OK. I guess I can test it but I'd rather replace both.
I can't get these parts, it seems.
Now what do I do? Oh great experts I beseech thee........
Edited by alexeinspruch, 06 February 2013 - 07:54 PM.
Treat me good, I'll treat you better. Treat me bad, I'll treat you worse.
#2 RegUS_PatOff
  • 30,242 posts
Posted 06 February 2013 - 08:07 PM
If the Compressor was "hot", then then white Overload seems to be working ..
You may want to use a Compressor Test Cord to see if the Compressor will "run"
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 06 February 2013 - 09:29 PM
If your compressor tests ok, you may be able to use a supco generic relay/overload pro81 designed for small compressors 1/12 to 1/3 hp. If you have a larger compressor then use the pro41. I've had good success with these relays.
Edited by DurhamAppliance, 06 February 2013 - 09:46 PM.
#4 alexeinspruch
alexeinspruch
    Sōhei
  • 125 posts
Posted 06 February 2013 - 10:48 PM
I will look into that THANKS. I still need to figure out how to test it.
#5 RegUS_PatOff
  • 30,242 posts
Posted 06 February 2013 - 11:22 PM
Compressor Test Cord Diagram is from SubZero 506 Service Manual
here's one from Amana Service Manual
#6 alexeinspruch
alexeinspruch
    Sōhei
  • 125 posts
Posted 06 February 2013 - 11:37 PM
Probably will cost more to make a test cord than swap the parts.......
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 07 February 2013 - 12:06 AM
True, but you won't have a cool tool with neat buttons and stuff to play with... uh... I mean.. you won't have a valuable learning device to hone your skills.
#8 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 07 February 2013 - 12:28 AM
I want 1. What size fuse? That'd be easier than wiring a hardstart in each time.
Do you have to connect the capacitor to test?
Edited by tpoindexter, 07 February 2013 - 12:35 AM.
Test
#9 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 07 February 2013 - 12:45 AM
Test
#10 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 07 February 2013 - 12:50 AM
This is the one i use Attached File  testcord.pdf   177.74K   14 downloads
  • 24,279 posts
Posted 07 February 2013 - 07:55 AM
Most of these relays are close enough in spec to be interchangeable.  This relay would work fine (assuming the compressor is okay) and is a drop-in replacement ==> http://www.repaircli...510013Q/1617267
Replacement overload ==> http://www.repaircli...410003S/1924722
#12 RegUS_PatOff
  • 30,242 posts
Posted 07 February 2013 - 09:45 AM
http://appliantology...ssor-overloads/
#13 alexeinspruch
alexeinspruch
    Sōhei
  • 125 posts
Posted 07 February 2013 - 02:08 PM
YOU GUYS FREAKING RULE.....I want to build the test cord. Looks fun. Local shop may have the replacement parts but ordering the generics above JIC.
Edited by alexeinspruch, 07 February 2013 - 02:20 PM.
#14 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 07 February 2013 - 02:20 PM
Yeah, repair guys rule while salesmen Drool :rocker:
