Whirlpool Top load Squeals in agitation like a stuck pig!
19 replies to this topic
#1 elmonducky
elmonducky
    Sōhei
  • Appliantologist
  • 128 posts
  • Flavorite Brew:Cabernet Sauvignon
Posted 06 February 2013 - 07:57 PM
 Have a whirlpool model WTW4800XQ0 washer that squeals like a pig in agitation.  Any ideas?
#2 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 06 February 2013 - 08:56 PM
  Just when it agitates? I was stumped for awhile trying to locate the pig noises on one of these. I tracked it down to the top of the suspension rods where they swivel. I slathered some grease in there and all was quiet. That's one possibility.
#3 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 06 February 2013 - 09:07 PM
opps again
Edited by tpoindexter, 06 February 2013 - 09:15 PM.
Test
#4 elmonducky
elmonducky
    Sōhei
  • Appliantologist
  • 128 posts
Posted 06 February 2013 - 09:10 PM
Its not squeaking from movement, its coming from the gearcase area. Its a very loud squeal not a squeak.
#5 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 06 February 2013 - 09:26 PM
opps again. I give up. I was trying to post a diagram
Edited by tpoindexter, 06 February 2013 - 09:28 PM.
Test
#6 LIONL56
LIONL56
  • Appliantologist
  • 16 posts
Posted 06 February 2013 - 11:01 PM
Its most likly one of 2 things, sus rods, or trans and seal, check the obvious, then spin basket by hand in each direction slow, if u here squeal, its from seal, I replace trans with new seal, under warranty
#7 elmonducky
elmonducky
    Sōhei
  • Appliantologist
  • 128 posts
Posted 06 February 2013 - 11:16 PM
AGAIN SUSPENSION RODS ARE NOT GOING TO LET OUT A LONG CONTINUOUS SQUEAL, LETS TRY TO THINK OUTSIDE THE BOX A LITTLE BIT! HAVE YOU EVER HEARD A SLIPPING BELT SQUEAL ON CAR THATS WHAT IT SOUNDS LIKE.  EVERY TIME I POST A PROBLEM I COME ACROSS ON A WHIRLPOOL WASHER EVEN IF ITS A BROKEN KNOB SOMEBODY SUGGESTS IT MIGHT BE SUSPENSION RODS!!!!!!!
ALSO WHEN ITS AGITATING THE TUBS NOT TURNING SO ITS NOT GOING TO BE A SEAL. THANKS FOR THE SUGGESTION ON THE TRANNY THAT WAS MY GUESS.
#8 DurhamAppliance
    Sho' Nuff Chozin
  • 1,756 posts
Posted 06 February 2013 - 11:18 PM
Tpoindexter... Keep trying, we don't mind and never ever give up:
#9 RegUS_PatOff
  • 30,299 posts
Posted 06 February 2013 - 11:24 PM
... A LONG CONTINUOUS SQUEAL,
I can't hear it from here...  :whistling:
post YouTube video ?
#10 DurhamAppliance
    Sho' Nuff Chozin
  • 1,756 posts
Posted 07 February 2013 - 01:12 AM
I would post the Youtube "squeal pig" scene from "Deliverance" to help you out but the scene is still too disturbing for me.
#11 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 07 February 2013 - 01:18 AM
  Thanks for finally letting a detailed explanation of your "squealing like a pig" noise out of the box elmonducky.
#12 DurhamAppliance
    Sho' Nuff Chozin
  • 1,756 posts
Posted 07 February 2013 - 01:25 AM
Ok I can handle this version... Does it sound like this?
#13 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 07 February 2013 - 01:28 AM
I wish I hadn't had to go see what you meant...shit my chest hurts...damn near gave me a heart attack.. Crap that's one of those images that'll take awhile to shake.
Test
#14 DurhamAppliance
    Sho' Nuff Chozin
  • 1,756 posts
Posted 07 February 2013 - 01:36 AM
Watch the parody version I just posted several times... It helps get rid of the original imagery.
Edited by DurhamAppliance, 07 February 2013 - 01:37 AM.
#15 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 07 February 2013 - 01:50 AM
Wish I had saw it first
Test
#16 suampman
suampman
    Sōhei
  • Chief Appliantologist
  • 161 posts
  • Flavorite Brew:redbridge
Posted 07 February 2013 - 09:06 AM
Just start taking it apart piece by piece and examine the parts that are most likely to be the problem. On these washers you can have the transmission out in 1/2 hr or less. Maybe there is some foreign object binding the machine. Best of luck.
#17 fairbank56
fairbank56
    Sōhei
  • 145 posts
Posted 07 February 2013 - 09:19 AM
  It doesn't turn continuously in one direction but it does turn back and forth, out of synch with the agitator due to the action of the planetary gear system in the gearcase and the fact that there is no braking mechanism. It's part of the design.
Eric
Edited by fairbank56, 07 February 2013 - 09:21 AM.
#18 elmonducky
elmonducky
    Sōhei
  • Appliantologist
  • 128 posts
Posted 07 February 2013 - 09:21 PM
Thanks, I was aware that it moved back and forth but discounted that being the problem because the squeal is not stop and go its one long squeal.  One other thing I noticed was that the pulley seemed to have a great deal of play but didi not seem to be slipping. Since its about 60 miles from my home im ordering a tranny, belt and pulley and hoping for the best.  Thanks for all the input, will let you know what I found.
#19 RegUS_PatOff
  • 30,299 posts
Posted 07 February 2013 - 09:55 PM
... im ordering a tranny, belt and pulley and hoping for the best.
http://www.repaircli...R=154&N=2312556
http://www.repaircli...R=154&N=1871380
http://www.repaircli...R=154&N=1871374
#20 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 07 February 2013 - 10:06 PM
None of the parts your taking are continuosly single directional in this case.
Have you actually heard the noise in person, or taking someone elses word. I only ask because you seem so convienced it couldn't be anything except something continuous, single directional.
But, if it can be multidirectional and make the squeal then I'm sure some of the suggestion have hit the mark.
Since you insist the noise is low, near tranny, my picks would be seal, belt, or pulley.
Test
