Kenmore Laundry Center 417.99680210
Dryer wont shut off
5 replies to this topic
#1 gary
gary
    Yamabushi
  • 60 posts
Posted 08 February 2013 - 08:03 PM
Hello.  I think I know the answer to my question, but I want to run it by the experts first.  A few weeks ago the dryer timer stopped working properly.  For example, if the dryer is set for one hour, the timer will only have moved about 20 minutes after an actual hour of drying time.  I think the following is the problem:
131063200 (sub 131719100) Dryer Timer Control Assembly.
http://www.repaircli...31719100/408125
Is that what I need to fix things up?
Cheers,
Gary
#2 RegUS_PatOff
  • 30,200 posts
Posted 08 February 2013 - 08:18 PM
... the timer will only have moved about 20 minutes after an actual hour of drying time.
on Timed Dry
OR Automatic Dry ?
How's the Vent system ?
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 1,716 posts
Posted 08 February 2013 - 08:19 PM
Few more questions to consider: Does it eventually shut off? Is there an auto dry mode, if so, what happens when you use it?
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 1,716 posts
Posted 08 February 2013 - 08:24 PM
Lol Reg you still the quickest draw around... Beat me by ¥ that much
#5 gary
gary
    Yamabushi
  • 60 posts
Posted 09 February 2013 - 01:47 PM
As far as I know we've only ever used the Timed Dry feature.  As far as ever turning off...  I just checked with my wife and she doesn't know if it would ever turn off.  I believe the vent system is OK.  It's been the same configuration for the past 15 years.  I have checked the vent pipe in the past, but don't recall the last time.  Maybe 3-4 years ago?  The dryer does dry clothes the same as always.  But no we set the stove timer to remind us to turn the dryer off.
#6 RegUS_PatOff
  • 30,200 posts
Posted 09 February 2013 - 06:04 PM
... timer will only have moved about 20 minutes after an actual hour of drying time
Clean your Vent System
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
 $ 3.99 sometimes on sale for $ 2.99
