Sealed System Problem
3 replies to this topic
#1 ApplianceDoctor
ApplianceDoctor
    Ikkō-ikki
  • Chief Appliantologist
  • 22 posts
Posted 09 February 2013 - 02:13 PM
I have a Frigidaire refrigerator that has a sealed system problem. I am not the greatest at diagnosing sealed system problems. The cap tube is icing up at the outlet where it connects to the inlet of the evaporator. Can anyone help me with the diagnosis on this problem.
#2 Strathy
Strathy
    Kohai
  • 382 posts
  • Flavorite Brew:DP.
Posted 09 February 2013 - 02:17 PM
Icing up as in a restriction ... or as in an ice ball?
If restricting there, then the system needs drying = blow it out with nitrogen and add a new filter dryer.
If an ice ball there (and the rest of the evap not frosted) then you have a system that is low on gas ... time to hunt for a leak.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 1,744 posts
Posted 09 February 2013 - 03:00 PM
I agree with Strathy but undertaking this repair certainly depends on the value of the fridge and whether it is a warranty call.  Usually, it means it's time to go shopping.
Edited by DurhamAppliance, 09 February 2013 - 03:02 PM.
#4 RegUS_PatOff
  • 30,262 posts
Posted 09 February 2013 - 06:10 PM
if it's a leak, may cost a few hundred dollars to:
find the leak
fix the leak (if it's in an "exposed" area)
evacuate and re-charge system
