I did another test load on the express cycle because this is what I normally use.
Whenever the machine got to the spin cycle, I stopped it and measured the residual water left before the spin. Exactly two cups came out of the machine.
I started the machine again so it would spin. The machine never did spin very fast. The machine then said clothes are done. I checked and of course they
were too damp.
I decided to try the drain and spin cycle. The machine drained (actually at this point there was no water left to pump), but the pump was activated for quite
a long time. The tub went at very slow speed clockwise and counterclockwise. Drained for what seemed like ten minutes or more, then started to spin.
Machine never did spin fast. Once again, I measured the amound of residual water left at the end of the drain and spin cycle - which was 1-1/2 cups.
I need some more ideas. Is there a service manual available for this or a like model number?
Help again!
