Maytag MVWC400XW1 washer won't agitate/spin
8 replies to this topic
#1 Belizeted
Belizeted
  • 4 posts
  • Flavorite Brew:local rum
Posted 10 February 2013 - 09:12 AM
I have a one year old Maytag Centennial top loading washer, which has been glitchy almost from the start, but lately will consistently not seem to agitate.  The washer apparently runs through all of the cycles but during the WASH it doesn't seem to agitate, but instead makes a pulsating humming sound.  The machine seems to fill and drain just fine, but seems to make weird noises during the SPIN cycle.  When the load finishes, the clothes are wet with soap on them.
Note: We are unable to purchase HE detergent in our area, so maybe this is part of the problem.  Are there any other equivalents?  We will try liquid soap, but for now the machine isn't really washing at all.  (We also have been running the washer through the recommended cleaning cycle with liquid bleach about once a month.)
Help!
#2 nickfixit
nickfixit
  • 1,965 posts
Posted 10 February 2013 - 10:50 AM
Check to see if the nut on the trans pulley has come loose. If so, add some blue locktite to the threads and tighten it back on. The belt may have rubbed the cover, usually the belt can be re-used and the cover doesn't really have any effect on operation of the machine
Nick
I would get some HE soap, even if you have to have it shipped. That washer needs all the help it can get cleaning clothes.
#3 Belizeted
Belizeted
  • 4 posts
Posted 10 February 2013 - 03:13 PM
Thanks Nick.  I checked the nut on the pulley and it seem tight.  The pulley and motor seem to move freely when I rotate it by hand.  On casual inspection, nothing seems amiss.
(Also, I do have a service manual for the machine.)
Any other ideas?
Ted
#4 Belizeted
Belizeted
  • 4 posts
Posted 10 February 2013 - 03:20 PM
Hold the phone.  I checked a little closer and there is a hole blown out of the side of the capacitor.   Do these normally blow or is this indicative of some other problem?
Ted
#5 RegUS_PatOff
  • 30,278 posts
Posted 10 February 2013 - 03:40 PM
pictures ?
#6 Belizeted
Belizeted
  • 4 posts
Posted 10 February 2013 - 05:50 PM
Attached File  capacitor1.jpg   38.48K   16 downloadsAttached File  capacitor2.jpg   36.5K   16 downloads
Thanks.  Here are two photos of the blown capacitor from two different angles.  There is a hole which blew out under the label and there is some squiggly melted plastic next to the mounting hole.
Ted
#7 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 10 February 2013 - 07:17 PM
That looks like your problem.
Scott Wolf
#8 RegUS_PatOff
  • 30,278 posts
Posted 10 February 2013 - 08:20 PM
yes, that's the "exploded view"
that may be the cause or the effect ..
Part number: W10278117
#9 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 10 February 2013 - 08:36 PM
Good one!
Scott Wolf
