Gas cook top; only one burner sparking; Frigidaire FGC3X4XFSA
3 replies to this topic
#1 scdgoofy
scdgoofy
  • 4 posts
Posted 10 February 2013 - 06:19 PM
Howdy,
I have a 4 burner Frigidaire FGC3X4XFSA gas cook top.  The front right burner sparks and lights just fine.  However, the other three burners have a problem.  When I try to spark and light them, they all spark the front right burner.  They will emit gas, but the spark is on the wrong burner.  I can manually light these other three burners, but I would like to get them all sparking and lighting on the proper control knobs.
Thanks!
-Steve
#2 RegUS_PatOff
  • 30,219 posts
Posted 10 February 2013 - 08:40 PM
On that (and most other) models,
when any Burner Knob is turned ON,
all of the Burners should "spark"
Sounds like a bad Spark Module
http://www.repaircli...R=154&N=1483923
#3 mastertech011
mastertech011
    Sōhei
  • Scholar of Appliantology
  • 116 posts
Posted 10 February 2013 - 09:43 PM
This is probably not related but I thought I would throw it in here. I recently decided to scrub the buildup off my gas burners with oven cleaner and soapy water. I got them so wet that three of them would no longer spark. I got a toothbrush and rinsed the spark tip off with fresh water and used a can of pressurized air from my computer room to blow out the excess water. When they dried they started sparking just fine again.
#4 RegUS_PatOff
  • 30,219 posts
Posted 10 February 2013 - 09:55 PM
This is probably not related but ...
definitely related ...
the "spark" is high-voltage ..
If the Ignitor terminals are wet.. they won't let the "spark" build up enough voltage to "jump" the gap
