True TSSU-60-16 prep table
5 replies to this topic
#1 certified tech group 51
  • 1,969 posts
Posted 12 February 2013 - 10:53 AM
Unit has no charge.............Old R12 system.........A lot of work to convert to a newer refrigerant.........Plus with all of the grease , I probably burn the place down..........Do not know if Hot-Shot  is the way to go......I am leaning towards Choice  R420A, but my parts house has not heard of it....Suppose to have the same P/T relationship, plus use the same oil.............I already have the Hot-Shot on hand........Anyone else use R420A ????.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 12 February 2013 - 11:09 AM
I have used 420a as a drop in for 12 for a few years...always worked great for me...approx. 10% less than rated charge, if memory serves...
#3 jumptrout
jumptrout
  • 1,124 posts
  • Flavorite Brew:Coors Light
Posted 12 February 2013 - 02:37 PM
HotShot is fine.
Since you have it on hand,use it.
#4 Cactus Bob
Cactus Bob
    Kohai
  • 431 posts
Posted 12 February 2013 - 08:06 PM
409A is another drop in replacement
Hot shot will work
True stopped using R12 in 1993-4 , so this unit is at least 19 years old
don't get married to it
SORRY ABOUT THE SPELLING , I FIX GREAT , I DON'T SPELL WELL
#5 dimitri77565
dimitri77565
    Ikkō-ikki
  • Chief Appliantologist
  • 52 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 12 February 2013 - 11:27 PM
I use hot shot for Old & new  R12 Or R134  also hot shot seems to clean small restrictions,  after charging add a "Leak Sealer"
unless u have a GE with the rusted return line witch normally u must replace due to the size of the HOLE (LOL).  Have used them for the last 2 years with %100 success.
 There are 2 types 1 is delivered by the oil in the system the other witch I prefer is delivered by the freon.   Many brands most are the same.
#6 certified tech group 51
  • 1,969 posts
Posted 14 February 2013 - 11:01 PM
Went to look for a jug of what i thought was R409 but it turns out to be  Suva MP 39 ( R 401A)........I think I will use the MP39.......... been there about 6 years , forgot about it....................This is what happens when the warehouse/shop has a lot of 'stuff' in it.. :rolleyes: ............Thanks  for the help.......
