My Duet Washer squeaks at low speeds and when I manually turn the drum. I took the back off the unit and the belt looks pretty good. The best I can tell is that the noise is coming from the axle on the drum. Is this a big deal, or just a minor annoyance. - Or an early sign that the bearings are going? Any suggestions on how to correct the problem?
Thanks.
Edited by mprocopi, 13 February 2013 - 06:38 AM.
