Jenn-Air Range Model# W30100B, F-2 code and beeping.
3 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 239 posts
  • Flavorite Brew:Root Beer
Posted 12 February 2013 - 05:26 PM
The cleaning people use the self clean on this a lot, and I suspect the F-2 code and beeping sound is due to a bad Thermal Fuse?  I'm having trouble finding the fuse, would it be P/N 71001844 ? or could it be a control board?  Thanks,
#2 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 894 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 12 February 2013 - 08:28 PM
F2= Over temperature sensed. Over 620F. Check sensor. If OK, Replace Power Relay Board.
Edited by Chat_in_FL, 12 February 2013 - 08:30 PM.
Mother Teresa
#3 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 12 February 2013 - 08:48 PM
http://www.repaircli...7939&locID=2452
http://www.repaircli...3344&locID=1870
Edited by tpoindexter, 12 February 2013 - 08:53 PM.
Test
#4 RegUS_PatOff
  • 30,188 posts
Posted 12 February 2013 - 10:51 PM
on any brand ...
each time you use self-clean, the heat puts a stress on everything ....
Running Your Oven's Self-Clean Could Mean Cold Turkey on Thanksgiving Day
:nono:
“My Rules”:
Rule #1) Don't ever use Self-Clean on any Oven.
Rule #2) If you're thinking about using Self-Clean, see rule #1.
That can wreak havoc on Electronic Controllers and Connections.
FAULT CODES . . . . PROBLEM . . . COMPONENTS TO CHECK
F1    Power to element relay activated J1, J2 wire harness connection to control shorted.
If during time of day display. checks ok, change control.
F2 Over temperature sensed  Ohm TEST SENSOR.   If checks ok, change control.
F3 Open sensor.   Ohm sensor.
F4 Shorted sensor.   Ohm sensor.
F5 Over temperature Ohm sensor.   Check connection of sensor wire harness.
F7 Shorted key Stuck Function Key on control.
F9 Door Code Check Latch Assembly.
For Models: W27100, W27200, W30100, WW27210, WM27260
(Oven Sensor Chart: Please refer to chart below)
