GE Topload Washer GTWP1800D0WW
Violent spin cycle
4 replies to this topic
#1 Patricio
Patricio
    Kohai
  • Chief Appliantologist
  • 438 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 15 February 2013 - 12:10 AM
Friend has a 5 month old GE washer.  Has it under warranty & had a factory authorized serviceman diagnose it as being out off balance.  Still out of balance cause it still bounces around.   Serviceman is coming back tomorrow & friend  ask me if I knew why it rocks & rolls so he can relay it.
  Got any ideas why?  I told him to run it in the rinse cycle with an empty load.  Friend used low water level   called me and informed me that he was a rough spin although not as rough as when loaded with clothes.  If the support rods weren't connected correctly I am sure the service man would have noticed.
IgonFishn & Tight Lines
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 15 February 2013 - 06:45 AM
I have had a real rash of these puppies with the concrete counter-weight loose...makes it shake like a hell .
Not sure how he would have missed that but..
#3 Patricio
Patricio
    Kohai
  • 438 posts
Posted 15 February 2013 - 02:06 PM
I knew that.  Senior moment.  :dazzler:    How  he missed it.... aaaa... not an independent. :whistling:
#4 suampman
suampman
    Sōhei
  • 156 posts
  • Flavorite Brew:redbridge
Posted 16 February 2013 - 11:00 PM
Or not linked in to the samurai crew.
#5 sh2sh2
sh2sh2
    Sōhei
  • 207 posts
  • Flavorite Brew:yeunling
Posted 17 February 2013 - 11:17 AM
i had one where the weight came loose and it was in a basement and the customer did not hear the noise, by the time it stopped working i had to replace the tub, mode shifter, the base that the tub hangs on, the motor inverter and the weight,
