Troubleshooting and Repairing an F/dL Error Code on a Whirlpool Duet Washer
whirlpool kenmore duet he4t washer f/dl f/11 fault code door lock tech sheet
No replies to this topic
#1 Samurai Appliance Repair Man
  • 24,243 posts
Posted 18 February 2013 - 07:05 PM
This video is for the German-built Whirlpool Duet as opposed to the Mexican-built Whirlpool Duet Sport.  Also sold under the Kenmore label as the HE4t.
F/dL is the fault code for a problem with the door lock assembly.  Also includes bonus info for the special and confounding cases where the F/11 code is also appearing.  F/11 is the fault code for a communications error between the CCU and the MCU but the CCU will also throw this code if it's not communicating with the door lock assembly.
Here's the part link to the new door lock assembly I installed to fix this problem:  http://www.repaircli...8182634/1094190
Also tagged with one or more of these keywords: whirlpool, kenmore, duet, he4t, washer, f/dl, f/11, fault code, door lock, tech sheet
