LG WASHER
DRAIN
2 replies to this topic
#1 dryerman45
dryerman45
    Ikkō-ikki
  • Chief Appliantologist
  • 58 posts
  • Flavorite Brew:rootbeer
Posted 18 February 2013 - 11:26 PM
I HAVE A LG WASHER THAT THE CUSTOMER IS COMPLAINING THAT SHE HAS TO EMPTY THE DRAIN TRAY AFTER EVERY WASH.SHE SAID SHE NEVER USE TO DO THIS AND IT STARTED ABOUT 2 MONTHS AGO.THE MODEL NUMBER IS
WM1812CW.YOUR HELP WOULD BE APPRECIATED AS TO WAHT NEEDS TO BE DONE TO CORRECT THIS
THANKS
SAMANERA
#2 john63
john63
  • 1,411 posts
Posted 19 February 2013 - 12:41 AM
<<<I HAVE A LG WASHER THAT THE CUSTOMER IS COMPLAINING THAT SHE HAS TO EMPTY THE DRAIN TRAY AFTER EVERY WASH.SHE SAID SHE NEVER USE TO DO THIS AND IT STARTED ABOUT 2 MONTHS AGO>>>
If the washer cycle ends---and there's water remaining in the tub (but no "OE" error is displayed)---replace the DRAIN MOTOR.
If the washer cycle ends---and the clothing is spun-dry---but the customer decided to "check" the Drain Strainer and low and behold---some water came gushing out (about 2-3 cups)---this is NORMAL.
Water must always remain in the Pump Housing---keeps the Drain Motor from damage if RUN/STARTED DRY.
If the washer cycle ends---and sometimes the load is spun-dry---but other times it is not---replace the DRAIN MOTOR.
If the washer cycle is *interrupted* periodically (shuts down) and displays an "LE" error---the incorrect type or amount of detergent is being used.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
  • 24,218 posts
Posted 19 February 2013 - 02:54 AM
Here's the drain pump part link  ==> http://www.repaircli...EA2001T/2003273
