Kenmore 253.60721002 refrigerator runs but won't cool
15 replies to this topic
#1 jonnyk
jonnyk
  • Chief Appliantologist
  • 11 posts
Posted 19 February 2013 - 10:32 AM
Kenmore 253.60721002 runs but won't cool
Startup amps: 6.5
Running amps: 1.1
(LRA on this compressor is 10.5 amps)
Start to Run: 28 ohms
Start to Common: 20 ohms
Run to Common: 9 ohms
Tested terminals to ground and none are grounded
Klixon overload is not open
Current relay tests ok
Compressor and discharge line feel warm to the touch but not excessively hot.
From my limited knowledge, the compressor ohm readings seem real high.  Is the compressor shot?
#2 jonnyk
jonnyk
  • 11 posts
Posted 19 February 2013 - 11:38 AM
Startup amps: 6.5
Running amps: 1.1
#3 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 167 posts
  • Flavorite Brew:guiness
Posted 19 February 2013 - 12:12 PM
what does the evaporator coil look like?all fans turning?
#4 jonnyk
jonnyk
  • 11 posts
Posted 19 February 2013 - 12:22 PM
evap coils are clean and evap fan is running
#5 RegUS_PatOff
  • 30,689 posts
Posted 19 February 2013 - 01:01 PM
a picture of the frost pattern of the Freezer Evaporator Coils may help..
Compressor readings could be OK..
possible leak in the Sealed System ..
either way could cost $$$ to repair ..
#6 tommytech
tommytech
    Sōhei
  • 167 posts
Posted 19 February 2013 - 02:14 PM
no frost on evap coil?
  • 24,698 posts
Posted 19 February 2013 - 03:12 PM
How to troubleshoot warm refrigerator problems by reading the evaporator frost pattern
  • 24,698 posts
Posted 19 February 2013 - 03:18 PM
Topics merged and moved to the Kitchen Forum (from the Orientation for New Students forum) bonghit.gif
#9 jonnyk
jonnyk
  • 11 posts
Posted 19 February 2013 - 04:38 PM
Nope. Not the slightest hint of frost on the evap coils after running for an hour.
  • 24,698 posts
Posted 19 February 2013 - 04:53 PM
Well, hate to break it to ya, pilgrim, but it looks like you're going shopping for a new beer cooler cuz yourn done shat the bed, as we professional Appliantologists say. That's customer-speak for sealed system damage-- not worth repairig.
#11 jonnyk
jonnyk
  • 11 posts
Posted 19 February 2013 - 06:49 PM
Fortunately it's not my fridge; it's one from work used to store "specimens"!  :woot:
So is "sealed system damage" slang for "I don't know what the mess happened but it can't be reasonably fixed"?
Or from you knowledge and experience do the signs point more to a compressor issue or a refrigerant leak or blockage?
Thanks for all your help.  Just paid for the Permapprenticeship and look forward to racking y'alls brains in the near future!
AWESOME SITE!!
#12 Samurai Appliance Repair Man
  • 24,698 posts
Posted 19 February 2013 - 06:52 PM
#13 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 19 February 2013 - 07:43 PM
Knowing the brand and using your stats I would say your system is restricted.
Most likely at the filter drier.
#14 jonnyk
jonnyk
  • 11 posts
Posted 19 February 2013 - 08:01 PM
I assume that since the fridge wasn't frosting over you are referring to this?
"For specific diagnostic help as to why the refrigerator is warming up, check out the warm refrigerator flow chart."
However, when I click on the link I am not seeing a flowchart.
This is all I see.
Next time your beer box is warming up, use this handy flowchart to
quickly figure out what’s wrong and get on the right track for fixing
it. Also makes a great gift for that special someone who already has it
all. Go ahead and download it now so you’ll have it handy in case your
beer starts warming up.
GDE Error: Unable to load profile settings
To learn more about your refrigerator, or to order parts, click here.
If you like this post, please share it with your friends using one of the share buttons below. Domo!
#15 Samurai Appliance Repair Man
  • 24,698 posts
Posted 20 February 2013 - 08:56 AM
Try it again, it seems to be working now ==> http://fixitnow.com/...ting-flowchart/
#16 jonnyk
jonnyk
  • 11 posts
Posted 20 February 2013 - 12:13 PM
Got it.  Thanks.
