frigidaire dryer gleq2152es1
flashing fault code flashing fault code
7 replies to this topic
#1 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 167 posts
  • Flavorite Brew:guiness
Posted 19 February 2013 - 11:34 AM
hello,i got a long distance customer who'se dryer flashes the dry/cool down/press care/clean vent lites 3 times and beeps when start button is pressed.said she can usually get it to work on a low temp,but not on normal/high.same result with vent disconnected.I'm guessing the flashing is a fault code,but i dont have a tech sheet/manual.Can you help? I want to have as much info and parts with me to avoid a second trip if possible. Thanks
#2 RegUS_PatOff
  • 30,670 posts
Posted 19 February 2013 - 03:36 PM
that model has the 3 digit read-out for fault codes
#3 tommytech
tommytech
    Sōhei
  • 167 posts
Posted 20 February 2013 - 10:34 AM
are you saying those 4 lites flashing 3 times is NOT a code? there are no digits
Edited by tommytech, 20 February 2013 - 07:38 PM.
#4 tommytech
tommytech
    Sōhei
  • 167 posts
Posted 20 February 2013 - 07:46 PM
can i get a tech sheet for that ?
#5 RegUS_PatOff
  • 30,670 posts
Posted 20 February 2013 - 08:31 PM
... there are no digits
then I don't think it's a
gleq2152es1
134509400efs.pdf
#6 tommytech
tommytech
    Sōhei
  • 167 posts
Posted 21 February 2013 - 12:55 PM
thanks for the info,guess im gonna hafta make that trip. can i get that info in a pdf file? having trouble with that link
#7 RegUS_PatOff
  • 30,670 posts
Posted 21 February 2013 - 01:06 PM
http://appliantology...yer-tech-sheet/
#8 tommytech
tommytech
    Sōhei
  • 167 posts
Posted 25 February 2013 - 09:26 AM
thanks for the help,im getting my info from the renters.
