JennAir Glass Cook Top Model# JEC0536ADB, Replacing Burner, How to Remove Top?
4 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 239 posts
  • Flavorite Brew:Root Beer
Posted 19 February 2013 - 11:37 PM
The big burner in the back/middle doesn't work and needs replacement.  Does anybody have the service manual or an idea on how to remove the glass and burners?  Thanks.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 19 February 2013 - 11:53 PM
You will have to completely remove the cooktop from the counter and unscrew the top from the burner box.
Scott Wolf
#3 RegUS_PatOff
  • 30,192 posts
Posted 20 February 2013 - 05:15 AM
from the service manual:
Main Top Removal
1. Disconnect power to cooktop.
2 Remove cooktop from installation position and place face down on protected surface.
3. Remove screws securing main top to burner box bottom.
4. Remove screws securing control panel box and conduit mounting plate to burner box assembly.
5. Remove main top.
6. Reverse procedure to reassemble, verifying that cooktop frame is properly aligned.
NOTE: Make sure the pieces of insulation, located in the front left and right rear corners,
are put back in place.
Failure to do so could create excessive cabinet temperatures.
Part link for the replacement heating element ==>  http://www.repaircli...mber=JEC0536ADB
Radiant-Surface-Element-74010158-0100474
Edited by Samurai Appliance Repair Man, 20 February 2013 - 09:04 AM.
Added part link.
#4 AlexM
AlexM
    Sōhei
  • 239 posts
Posted 20 February 2013 - 06:11 AM
Is the downdraft vent separate from the cook top? and will I have to remove it to get the top out?
#5 RegUS_PatOff
  • 30,192 posts
Posted 20 February 2013 - 08:36 AM
I think it's separate, and has a separate part number.
How to Replace a Radiant Burner in a Jenn-Air Glass Electric Cooktop
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 20 February 2013 - 09:00 AM
Part link for the replacement burner ==> http://www.repaircli...mber=JEC0536ADB http://www.rcapplian...1004742.jpgTo learn more about your cooktop or to order parts, click here .  Source: JennAir Glass Cook Top Model#...
Read Full Entry →
