Maytag D.W. Model# MDB7760AWS0, Intermittent power.
5 replies to this topic
#1 AlexM
AlexM
    Kohai
  • Chief Appliantologist
  • 263 posts
  • Flavorite Brew:Root Beer
Posted 20 February 2013 - 06:03 PM
This issue was that there was no power to the unit.  When i went out to check the unit, i found that the controls and everything worked fine.  I took off the front and cleaned the wire connections and re-plugged everything back in.  I also checked the thermal fuse and it was good.  I tested the unit again and everything seemed ok when i left.  I also checked for 120 volt at the wall and it was good.  Now  the customer called back and there is no lights or power to the unit, is there something else i should be looking for?
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,505 posts
  • Flavorite Brew:Killians Red
Posted 20 February 2013 - 06:08 PM
First thing I check with this type problem on a DW is the J box wirenut connectors.
#3 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Is this connected to a dedicated circuit?
Is the circuit on a switch?
#4 RegUS_PatOff
  • 30,696 posts
Posted 20 February 2013 - 06:15 PM
http://fixitnow.com/...hwasher-repair/
#5 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 20 February 2013 - 11:57 PM
I had a customer like this that moved into a new house, she didn't realize there was a wall switch that controlled the dishwasher.  She kept turning the switch off.  It worked fine when I was there because I would turn all the lights on and the switch that controlled the dishwasher.
Scott Wolf
#6 maytagman
maytagman
    Ikkō-ikki
  • 56 posts
  • Flavorite Brew:Spotted Cow
Posted 21 February 2013 - 01:50 AM
I would lean towards the touch panel on that model, but obviously thats just a guess.  Ask the customer if it was acting goofy for awhile before it went dead. Sometimes only certain buttons will work or you have to push multiple times to get it to go. Verify correct voltage to unit and then check out that touchpanel.
