Frigidaire model # FTFB4000FS1 it wont drain or spin
e23 e21
7 replies to this topic
#1 lab76us
lab76us
  • 6 posts
  • Flavorite Brew:Molson Ice
Posted 21 February 2013 - 10:05 AM
Hi,
I have Frigidaire model # FTFB4000FS1 it wont drain or spin. I think the problem started with a very heavy load. I cleaned the pump motor and drain hose and the filter basket. there was a few coins and hair and threads but not a lot. I also changed the wax motor (does the wax motor connecter need to be plugged in one way or does it make a difference if so how do you figure which way it plugs in). I was receiving e23 but when I replaced wax motor I got e21.I hear a hum when the washer should be draining
I would appreciate any help you can give me
  • 24,288 posts
Posted 21 February 2013 - 10:16 AM
The rule with front loaders is, "No pumpy, no spinny."  The hum you're hearing could be the sound of the pump motor trying to run but with the impeller jammed it's just humming.  Need to pull the pump out and turn the impeller with your finger, make sure it turns freely.  You may find something like this:
or this:
Also, disconnect the drain hose from the pump and blow through it to make sure it's not clogged.
If the impeller and drain hose are clear, replace the drain pump ==> http://www.repaircli...ber=FTFB4000FS1
#3 lab76us
lab76us
  • 6 posts
Posted 22 February 2013 - 10:20 AM
  • Dear Fermented Grand Master,
  • Thank you for your wise wisdom. The Impeller moves freely,so it's replace the pump motor.
  • I'm also replacing the motor control board 134743500. With your vast knowlege are there instructions to replace this part???
  • Thank you Sensei
  • Your Humble student
  • A Jay Burke
#4 RegUS_PatOff
  • 30,245 posts
Posted 22 February 2013 - 11:12 AM
... so it's replace the pump motor.
... I'm also replacing the motor control board 134743500.
why both ?
did you check for 120v AC at the Pump Motor ?
  • 24,288 posts
Posted 22 February 2013 - 08:54 PM
why both ?
He's hearing the characteristic pump hum during pump out, meaning the pump is either trying to run and failing or it is running but the drain hose is clogged.
#6 vee8power
vee8power
    Sōhei
  • 118 posts
  • Flavorite Brew:Folgers
Posted 24 February 2013 - 07:02 AM
Whoa! Master, I covet those hose clamp pliers laying in the bottom of that washer. You know the part number?
  • 24,288 posts
Posted 24 February 2013 - 07:09 AM
They're handy! I don't know the part number but I got 'em from Sears, they're standard automotive hose clamp pliers. I've refined my technique using a wet vac, as shown in this video:
#8 lab76us
lab76us
  • 6 posts
Posted 04 March 2013 - 03:10 PM
do you have video to change the
Motor Control Board 134743500???
used you vac method and  not get a drop of water escaped
