MEDE300VW0 Keeps blowing Thermal Fuses
7 replies to this topic
#1 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 31 posts
Posted 21 February 2013 - 09:27 PM
This model doesn't have a tech sheet. The dryer has been vacuumed,thermal fuse was replaced(blown)  cut-off kit replaced and a lint trap kit was installed. Customer stated maintenance came and cleaned out the Ducting system and reassembled the vent hose. Dryer has stop working again. Does anyone have the tech sheet? Does anyone know the reading I should get on the thermistor? Lastly the element was ohmed to ground on both leads no shorts.
#2 Wingerman
Wingerman
    Yamabushi
  • 77 posts
  • Flavorite Brew:Cuervo Silver and Lemonade
Posted 21 February 2013 - 10:20 PM
"Customer stated maintenance came and cleaned out the Ducting system and reassembled the vent hose"
Double check the work of the maintenance guy. Also, if the ducting system has a power vent motor, check to make sure the motor is working.  There's normally a pressure switch on these, not unlike a water level pressure switch on a washing machine, that senses pressure and turns the motor on. Don't forget to check the vanes on the blower motor wheel; the vanes often stop up with lint so the motor doesn't end up moving much exhaust air. The thermistor is about 10K ohm. The Samurai has a featured article on testing vents.
Edited by Wingerman, 21 February 2013 - 10:31 PM.
#3 RegUS_PatOff
  • 30,188 posts
Posted 21 February 2013 - 10:34 PM
describe (or photos) Vent system material / length / etc
#4 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 31 posts
Posted 22 February 2013 - 04:10 AM
I'll find out about the vent system in the morning. I'll double check everything you stated. Thanks fellas!!! :rocker:
#5 sh2sh2
sh2sh2
    Sōhei
  • 207 posts
  • Flavorite Brew:yeunling
Posted 22 February 2013 - 07:16 PM
relay on control board stuck closed, always heating.  Run it on air dry and see if it heats up
#6 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 31 posts
Posted 21 April 2013 - 09:04 PM
I gave a refund on this one and walked away. No tech sheet was available. The board had to be the issue,
#7 RegUS_PatOff
  • 30,188 posts
Posted 21 April 2013 - 10:03 PM
... and everything mentioned above was checked ?
was waiting for your responses
this may be similar
MEDE300VW1
Tech Sheet - W10258376.pdf
#8 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 31 posts
Posted 22 April 2013 - 11:00 AM
GOT THE TECH SHEET THANKS!!! YOU GUYS ROCK :rocker:
